Maniphest T60245
Crash when opening file Segmentation Fault
Closed, Duplicate
None
Eric Butts (ebutts531)
Jan 6 2019, 10:36 PM
  • BF Blender
version: 2.80 (sub 40), branch: master, commit date: 2019-01-06 10:51, hash: 6c7762687e57, type: Release
build date: 2019-01-06, 11:35:38
platform: Linux
Blender crashes immediately when opening file. If I save in 2.79 then open from 2.80 it will load. If I save in 2.80 it will not open again. Attached are the terminal errors, crash.txt, and file. New config file for 2.80 has no effect. Linux system is current. Does not open in the previous recent builds as well. Workaround is to append objects into new scene.
Related Objects
Mentioned Here
rB6c7762687e57: Fix T60187: Latest couple of builds fail to run, need libGLX.so.0
Eric Butts (ebutts531) created this task.Jan 6 2019, 10:36 PM
Eric Butts (ebutts531) renamed this task from Crash when opening file to Crash when opening file Segmentation Fault.Jan 7 2019, 12:13 AM
Eric Butts (ebutts531) updated the task description.
Brecht Van Lommel (brecht) closed this task as a duplicate of T60213: Overide material kill blend file.Jan 7 2019, 10:39 AM
