Maniphest T60272
Materials from 2.79 not working properly to 2.8 EEVEE
Closed, Duplicate
None
david law (Ponlets)
Jan 7 2019, 4:05 PM
  • BF Blender
Brecht Van Lommel (brecht)
david law (Ponlets)
Jacques Lucke (JacquesLucke)
William Reynish (billreynish)
Operating system: windows 10 pro 64 bit
Graphics card: GTX 1080 ti
Broken: 2.8
(example: 2.79b release)
Worked: (optional) 2.79
when i open a 2.79 blender file with 2.8 90% of everything works save for a few custom bone shapes and textures/materials
cycles materials should always seamlessly work with EEVEE .. i can understand lighting to not always work but materials should function the same in both and look nearly identical in every situation with only the messing about with lights to match lit conditions
a way to replicate this is to make a scene in 2.79 with several UV mapped and textured objects (make them material heavy if possible) and then have a few of those in scene and then to open the same file with 2.8
attached should be the file i am having issues with
this particular one has an issue with the body shader even though its UV mapped properly for the exterior (i should see it work right in EEVEE as it works right in Cycles in 2.79)
david law (Ponlets) created this task.Jan 7 2019, 4:05 PM
david law (Ponlets) added a comment.Jan 7 2019, 4:21 PM
here is the Cycles version as well (2.79 version) as the one in the main Post is the 2.8 version
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).Jan 7 2019, 4:26 PM
I can't reproduce an issue.
Seems to work fine:
david law (Ponlets) added a comment.EditedJan 7 2019, 4:59 PM
Seems to work fine:
dude
hes supposed to be green not blackish
look at the UV map for "pony2" its the green one
it should already open the uv map to that texture
in the shader option for "diffuse bits" the preview shows the green texture with shading
but does not work properly with the model in final render (EEVEE) and with viewport render
download and open the 2.79 cycles version and set that to material viewport (with blender 2.79) and see how it should look
david law (Ponlets) added a comment.Jan 7 2019, 5:04 PM
this is how he should look
(rendered with Cycles in 2.79)
EEVEE breaks it for some reason even though its using the EXACT SAME MATERIAL)
david law (Ponlets) added a comment.Jan 7 2019, 5:55 PM
i cant place whats wrong here
image 1 (2.79 cycles)
image 2 (2.8 EEVEE)
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 30.Jan 8 2019, 1:05 PM
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).
@david law (Ponlets) Can you reproduce the issue in another (smaller) file? Or can you try to remove everything from the file that is not necessary to show the bug?
Brecht Van Lommel (brecht) closed this task as a duplicate of T59304: Booleans and textures with UV coordinate.Jan 9 2019, 12:57 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
It's a problem with the boolean modifier and UVs, for which we have another report.
