Maniphest T60287
Sculpting LAG using SubD Surface Mod in 2.9
Closed, Archived
Brecht Van Lommel (brecht)
jason hightower (bogeystudios)
Jan 7 2019, 6:43 PM
  • BF Blender
William Reynish (billreynish)
Operating system: Windows 10
Graphics card: 900 series nvidia
Blender Version 2.9
Broken:
(example: 2.79b release)
Exact steps for others to reproduce the error THIS happens in sculpt mode. Not sure if I mentioned that in the last report.
1.) Delete all objects on startup.
2.) Shift-A--> Make iconosphere
3.) Add Sub D mod
4.)Sculpt mode.
Lag when using any of the brushes. This did not occur in 2.79
Repeating these steps but instead adding Multires causes object to momentarily disappear when turning object.
jason hightower (bogeystudios) created this task.Jan 7 2019, 6:43 PM
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).Jan 7 2019, 7:22 PM
Can you try using Blender 2.8, and an up-to-date version?
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Jan 8 2019, 11:11 AM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
See:
https://wiki.blender.org/wiki/Reference/Release_Notes/2.80/Modeling#Subdivision_Surfaces_and_Multires
Note however there are still some missing features and performance problems in the new implementation. Particularly animation playback and moving of vertices in edit mode will be improved before the final 2.80 release, to bring it back to 2.7x level.
