Operating system: Win 10
Graphics card: AMD R7 265
Broken:2.80 Beta
(example: 2.79b release)
Compiling OpenCL program split
OpenCL build failed with error CL_BUILD_PROGRAM_FAILURE, errors in console.
OpenCL program split build output: "source\kernel/kernel_volume.h", line 394: error: expression must have
pointer-to-struct-or-union type
if(rand < pdf->x) {
^"source\kernel/kernel_volume.h", line 397: error: expression must have
else if(rand < pdf->x + pdf->y) {
^3 errors detected in the compilation of "C:\Users\Karthik\AppData\Local\Temp\OCL9568T4.cl".
Frontend phase failed compilation.
Split kernel error: failed to load kernel_path_init
Error: Split kernel error: failed to load kernel_path_init
if(rand < pdf->x) {
