Maniphest T60352
Blender 2.8 GPU OpenCL Render Failed (Split Kernal)
Closed, Duplicate
None
Karthik Hebbar (deltamish)
Jan 9 2019, 5:37 PM
  • BF Blender
Brecht Van Lommel (brecht)
Operating system: Win 10
Graphics card: AMD R7 265
Broken:
(example: 2.80 Jan 8/2019 version
Device init success
Device init success
Compiling OpenCL program split
OpenCL build failed with error CL_BUILD_PROGRAM_FAILURE, errors in console.
OpenCL program split build output: "source\kernel/kernel_volume.h", line 394: error: expression must have
  pointer-to-struct-or-union type
if(rand < pdf->x) {
"source\kernel/kernel_volume.h", line 397: error: expression must have
else if(rand < pdf->x + pdf->y) {
3 errors detected in the compilation of "C:\Users\Karthik\AppData\Local\Temp\OCL7072T1.cl".
Frontend phase failed compilation.
Split kernel error: failed to load kernel_path_init
Error: Split kernel error: failed to load kernel_path_init
Karthik Hebbar (deltamish) created this task.Jan 9 2019, 5:37 PM
Brecht Van Lommel (brecht) closed this task as a duplicate of T60320: OpenCL Cycles Render Fail.Jan 9 2019, 5:50 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
It's not needed to open a secondary report, we can reopen the first one if needed.
The January 8 build did not include the fix yet, it will be in the next one.
