Maniphest T60366
Creating a new image texture in shader editor does not appear among the texture slots
Confirmed, LowBUG
None
Balazs Oszvald (psnsgr)
Jan 9 2019, 9:16 PM
  • BF Blender
  • Render & Cycles
  • Sculpt, Paint & Texture
Brecht Van Lommel (brecht)
Dalai Felinto (dfelinto)
Erik Selin (thurines)
Philipp Oeser (lichtwerk)
Richard Antalik (ISS)
Windows 10 Pro 64bit, AMD Ryzen 5 2600, 16Gb RAM
NVidia GTX 1060 6Gb
Windows 10 Pro 64bit, AMD Ryzen 5 1600, 8Gb RAM
NVidia GTX 1050Ti 4 Gb
Blender 2.8 Beta 91a155833e59
If you are texture painting in one window and you modify the shader by adding/removing an image texture to it in another, it won't appear/disappear from the texture slot list until you change to edit mode (or anything else) and back. Another issue is that this way you can paint onto an image texture that is no more connected to the shader and it doesn't disappear even if you do the "edit mode and back" (TAB x2) trick.
Steps: Add an image texture to the shader in the attached file, connect to the roughness for example, create a new texture for. It won't be in the texture slots list. Now TAB x2 in the 3D view, slot appears. Paint on it, delete the node from the shader. It is still in the list. TAB x2. It is no more in the list, but the 3D view still shows the texture.
Revisions and Commits
rB Blender
Related Objects
Mentioned In
T76017: Image Pin=false , but Image Editor not refresh to the selected image node in Shader Editor
rBa261d6f2d3fe: Fix T62328, T62209: revert recent fix for texture slots updates (T60366).
Balazs Oszvald (psnsgr) created this task.Jan 9 2019, 9:16 PM
Sebastian Parborg (zeddb) assigned this task to Brecht Van Lommel (brecht).Jan 25 2019, 6:48 PM
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved by committing rBda1323d1c950: Fix T60366: texture paint slots not updating when editing material..Feb 28 2019, 7:18 PM
Brecht Van Lommel (brecht) added a commit: rBda1323d1c950: Fix T60366: texture paint slots not updating when editing material..
Brecht Van Lommel (brecht) changed the task status from Resolved to Unknown Status.Mar 7 2019, 7:43 PM
Brecht Van Lommel (brecht) lowered the priority of this task from 50 to Low.
Brecht Van Lommel (brecht) mentioned this in rBa261d6f2d3fe: Fix T62328, T62209: revert recent fix for texture slots updates (T60366)..Mar 7 2019, 7:43 PM
Brecht Van Lommel (brecht) added a subscriber: Erik Selin (thurines).
Dalai Felinto (dfelinto) removed Brecht Van Lommel (brecht) as the assignee of this task.Dec 23 2019, 4:35 PM
Dalai Felinto (dfelinto) added a project: Tracker Curfew.
Dalai Felinto (dfelinto) added a subscriber: Brecht Van Lommel (brecht).
Richard Antalik (ISS) closed this task as Resolved.Jan 22 2020, 6:57 PM
Richard Antalik (ISS) claimed this task.
Richard Antalik (ISS) removed a project: Tracker Curfew.
Philipp Oeser (lichtwerk) reopened this task as Confirmed.Jan 22 2020, 7:03 PM
This is not resolved.
@Richard Antalik (ISS): have you actually checked this?
Philipp Oeser (lichtwerk) changed the subtype of this task from "Report" to "Bug".Jan 22 2020, 7:04 PM
Dalai Felinto (dfelinto) added projects: Nodes & Physics, Animation & Rigging, Dependency Graph.Jan 23 2020, 10:25 AM
Dalai Felinto (dfelinto) added a subscriber: Dalai Felinto (dfelinto).
@Richard Antalik (ISS) indeed the issue is still there. We should only close these reports without confirmation from users if you can guarantee it worked in the reported version (so you managed to reproduce it), but then not in the latest Blender.
Sybren A. Stüvel (sybren) moved this task from Backlog to Bugs on the Animation & Rigging board.Feb 17 2020, 5:45 PM
Richard Antalik (ISS) removed Richard Antalik (ISS) as the assignee of this task.Feb 27 2020, 2:48 PM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
Brecht Van Lommel (brecht) edited projects, added Render & Cycles; removed Dependency Graph, Animation & Rigging, Nodes & Physics.
Brecht Van Lommel (brecht) added a project: Sculpt, Paint & Texture.
Julien Kaspar (JulienKaspar) moved this task from Backlog to Bugs on the Sculpt, Paint & Texture board.Apr 20 2021, 1:10 PM
