Operating system: Ubuntu 18.04.1 LTS
Broken: 95736683a96d33a8a7220788502250fa9e109132
When cutting a meta strip, the F-curves linked to the strips inside the meta are copied, but the property indicators for the right meta-strip do not update until a keyframe is added/changed
- Open a new "Video Editing" file
- Add a "color" strip
- Set two keyframes to the "opacity" property of this strip (example : at frame 1, opacity=1, at frame 25 opacity=0)
- Soft-cut this strip at frame 15 (K)
- Open a graph editor, and see that the F-curve has correctly been duplicated by selecting the two halves one after the other
- Select the first half, in the properties panel, watch the "Opacity" value as you scrub over the first half. The opacity changes as expected
- Select the second half, in the properties pane, watch the "Opacity" value as you scrub over the second half. The opacity does not change
- With the second strip selected, in the graph editor, select and move a keyframe, but cancel the move by hitting ESC or right-mouse. Now the opacity changes as expected when scrubbing
