Maniphest T60381
Errors on OBJ import
Closed, Resolved
Bastien Montagne (mont29)
SagRU (SagRU)
Jan 10 2019, 5:57 AM
  • BF Blender
  • Import/Export
  • Add-ons (Community)
Philipp Oeser (lichtwerk)
SagRU (SagRU)
Operating system: Windows 10 Pro 64Bit
Graphics card: Intel HD Graphics 530
Broken: 2.80, January 08, 01:07:30 - 91a155833e59
Worked: 2.79b
When I try to import my OBJ model, I get these errors in console:
(  0.0000 sec |   0.0000 sec) Importing OBJ 'C:\\cygwin64\\home\\user\\RendererAPI\\files\\renders\\render_794\\project.obj'...
  (  0.0010 sec |   0.0010 sec) Parsing OBJ file...
    (  1.3310 sec |   1.3301 sec) Done, loading materials and images...
WARNING, currently unsupported 'tr' translucency option, skipped.
  File "C:\Users\user\Desktop\blender-2.80.0-git.91a155833e59-windows64\2.80\scripts\addons\io_scene_obj\__init__.py", line 145, in execute
    return import_obj.load(context, **keywords)
  File "C:\Users\user\Desktop\blender-2.80.0-git.91a155833e59-windows64\2.80\scripts\addons\io_scene_obj\import_obj.py", line 1173, in load
    use_image_search, float_func)
  File "C:\Users\user\Desktop\blender-2.80.0-git.91a155833e59-windows64\2.80\scripts\addons\io_scene_obj\import_obj.py", line 397, in create_materials
    context_material_name, img_data, line, 'Kd')
  File "C:\Users\user\Desktop\blender-2.80.0-git.91a155833e59-windows64\2.80\scripts\addons\io_scene_obj\import_obj.py", line 139, in load_material_image
    _generic_tex_set(mat_wrap.base_color_texture, image, 'UV', map_offset, map_scale)
  File "C:\Users\user\Desktop\blender-2.80.0-git.91a155833e59-windows64\2.80\scripts\addons\io_scene_obj\import_obj.py", line 135, in _generic_tex_set
    nodetex.scale = scale
  File "C:\Users\user\Desktop\blender-2.80.0-git.91a155833e59-windows64\2.80\scripts\modules\bpy_extras\node_shader_utils.py", line 37, in wrapper
    return func(self, *args, **kwargs)
  File "C:\Users\user\Desktop\blender-2.80.0-git.91a155833e59-windows64\2.80\scripts\modules\bpy_extras\node_shader_utils.py", line 733, in scale_set
    self.node_mapping.scale = scale
TypeError: bpy_struct: item.attr = val: expected sequence items of type float, not bytes
I removed all "Tr" parameters from corresponding MTL file, but it didn't help much:
(  0.0000 sec |   0.0000 sec) Importing OBJ 'D:\\Render_Test\\project.obj'...
  (  0.0020 sec |   0.0020 sec) Parsing OBJ file...
    (  1.3280 sec |   1.3260 sec) Done, loading materials and images...
    (  1.3310 sec |   1.3290 sec) Done, building geometries (verts:98496 faces:32564 materials: 7 smoothgroups:0) ...
Error: Array length mismatch (expected 63072, got 63000)
  File "C:\Users\user\Desktop\blender-2.80.0-git.91a155833e59-windows64\2.80\scripts\addons\io_scene_obj\import_obj.py", line 1201, in load
    dataname,
  File "C:\Users\user\Desktop\blender-2.80.0-git.91a155833e59-windows64\2.80\scripts\addons\io_scene_obj\import_obj.py", line 674, in create_mesh
    me.uv_layers[0].data.foreach_set("uv", loops_uv)
RuntimeError: internal error setting the array
  1. Download an attached model
  2. Open Blender 2.8
  3. Try to import the model as Wavefront (OBJ)
Related Objects
Mentioned In
rBA5509187b4dc3: Fix second part of T60381: OBJ import of textures would fail when map…
T60387: Blender 2.8 OBJ file format not work in import mode
rBA9448cef00d1b: Fix first part of T60381: OBJ import broken in case of multiple OBJ objects…
SagRU (SagRU) created this task.Jan 10 2019, 5:57 AM
Philipp Oeser (lichtwerk) assigned this task to Bastien Montagne (mont29).Jan 10 2019, 9:43 AM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.
Philipp Oeser (lichtwerk) added projects: Import/Export, Add-ons (Community).
Philipp Oeser (lichtwerk) added subscribers: Bastien Montagne (mont29), Philipp Oeser (lichtwerk).
Regarding the translucency error: could you share the MTL without 'Tr' being removed?
[easier to repro and fix the first issue]
Can confirm the UV mismatch.
@Bastien Montagne (mont29) might know right away? (feel free to throw back at me and I will investigate more...)
[This might not be a bug but a broken OBJ though... where has this been exported from?]
Philipp Oeser (lichtwerk) added a comment.Jan 10 2019, 11:35 AM
note: this is coming in without errors in 2.79...
Bastien Montagne (mont29) added a comment.Jan 10 2019, 2:53 PM
UV error comes from the fact that this .obj has two objects named the same ('_1'), I think… will check and fix that (2.79 seems to always fully merge those into a single mesh, while it looks like 2.8 does an hybrid work which generates that mismatch in UV numbers).
original report, the warning itself is nothing wrong, just some unsupported feature. the actual error I'll need unmodified MTL again to investigate.
Bastien Montagne (mont29) mentioned this in rBA9448cef00d1b: Fix first part of T60381: OBJ import broken in case of multiple OBJ objects….Jan 10 2019, 3:26 PM
Bastien Montagne (mont29) lowered the priority of this task from 50 to 30.Jan 10 2019, 3:30 PM
UV part is fixed, marking as incomplete until we get original MTL to investigate material issue.
SagRU (SagRU) added a comment.Jan 11 2019, 4:08 AM
Here's a pure MTL file (as exported from a three.js app):
SagRU (SagRU) added a comment.Jan 11 2019, 7:59 AM
It seems that missing textures break the import. When I remove all Kd lines, the importer works fine. In 2.79b it wasn't a road-block.
Bastien Montagne (mont29) changed the task status from Unknown Status to Resolved.Jan 11 2019, 11:02 AM
Bastien Montagne (mont29) raised the priority of this task from 30 to 50.
fixed in rBA5509187b4dc, thanks.
Bastien Montagne (mont29) mentioned this in rBA5509187b4dc3: Fix second part of T60381: OBJ import of textures would fail when map….Jan 11 2019, 11:03 AM
