Maniphest T60418
Undo - One step back takes very long
Closed, Duplicate
None
Marcus Papathoma (machieb)
Jan 11 2019, 12:58 PM
  • BF Blender
Andrew Williams (sobakasu)
Brecht Van Lommel (brecht)
Operating system: Windows 10 Pro x64
Graphics card: Geforce GTX 1080Ti
Broken: all
Worked: never
Undo - To undo one step takes very long!
I now had the time to prepare a testscene. At the Blender Conferece I think Sergey said, we should send a file to repoduce the problem. He or another developer will have a look!
The scene reflects the object and polycount, we have in our production files.
In other programs we use, with the same poly and object count, undo works in a second. So the object or polycount couldn´t be an excuse.
Open the attached Scene
Select one cube.
Rotate the cube.
Undo that step by clicking Ctrl+Z, count the time that it takes. On my system it was about 20sec. Thats a lot for only one undo step!
Please make undo faster!
I tested the attached scene on two different computers.
One at work. AMD Threadripper 1950X 16CoresQ3,4 GHz - here it takes 17sec do undo the cube rotation.
One at home. Intel Xeon E5-2697v3 2x14Cores@2,6GHz - here it takes only 21sec do undo the cube rotation.
But that is only one undo step. Undoing multiple undo steps takes longer.
I hope it is worth to investigate it further?!
Marcus Papathoma (machieb) created this task.Jan 11 2019, 12:58 PM
Marcus Papathoma (machieb) updated the task description.Jan 12 2019, 5:46 PM
Marcus Papathoma (machieb) renamed this task from Undo - One step back takes more than a minute to Undo - One step back takes very long.Jan 14 2019, 10:26 AM
Andrew Williams (sobakasu) added a subscriber: Andrew Williams (sobakasu).Jan 20 2019, 1:41 AM
i started to write some code that could speed up undo by over 9000 times
Marcus Papathoma (machieb) added a comment.Jan 20 2019, 10:51 AM
Thats realy great!
Brecht Van Lommel (brecht) closed this task as a duplicate of T60695: Optimized per-datablock global undo.Jan 24 2019, 8:08 AM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Merged into design task with details on how to solve this. Not strictly a bug given the current design.
