Maniphest T60483
Side panels show scale icon from to bottom
Closed, Duplicate
None
Rombout Versluijs (rombout)
Jan 14 2019, 1:51 AM
  • BF Blender
Jacques Lucke (JacquesLucke)
William Reynish (billreynish)
OSX 10.11.6
Intel Iris Pro 1536 MB
2.80, 3c3d80ea22af, 2019-01-08 23:33
In 2.80 we now have new panels which dont show a background by default. However the scale function can be triggered still which got me stuck sometimes because i wasnt sure what was happening.
  1. hover with mouse over location on the side where panels are.
  2. Press ALT + LMB, this activates panel scroll mode.
  3. As there is no panel background i thought i was stuck i couldnt move
Should the scroll function really be able to activate when no panel is behind it?
Rombout Versluijs (rombout) created this task.Jan 14 2019, 1:51 AM
Jacques Lucke (JacquesLucke) added subscribers: William Reynish (billreynish), Jacques Lucke (JacquesLucke).Jan 14 2019, 10:25 AM
@William Reynish (billreynish), maybe this is more a paper cut instead of a bug?
Jacques Lucke (JacquesLucke) mentioned this in T60486: Brush disappears under sidebar.Jan 14 2019, 11:29 AM
Rombout Versluijs (rombout) added a comment.Jan 14 2019, 5:41 PM
Not sure what paper cut has to do with functional design???
But it shows that the complete transparent panels do have a small issue.
William Reynish (billreynish) added a comment.Jan 15 2019, 12:25 PM
@Jacques Lucke (JacquesLucke) Not sure. We could make it so you can only resize the panels when you are over a panel, not the region, and let the view manipulation fall through to the 3d view when in an empty area?
This would be a bit strange if the region background is 100% opaque though - but may be ok?
Jacques Lucke (JacquesLucke) added a comment.Jan 15 2019, 12:29 PM
Another solution could be to make the side bars not 100% when a mouse hovers over it.. Just to show that there is something.
If it is 100% transparent I'd also expect that all the tools work there. Not sure how hard it is to make that work.
William Reynish (billreynish) added a comment.Jan 15 2019, 12:32 PM
@Jacques Lucke (JacquesLucke) With the toolbar especially, we gain a lot of space by making the toolbar float on a transparent background. It'd be a shame to get rid of that - even if only on hover.
Overall I would probably prefer to do the opposite thing of making the input fall through to the 3d view if there is no panel.
Brecht Van Lommel (brecht) closed this task as a duplicate of T59789: Region below transparent sidebar panels captures mouse input.Jan 15 2019, 1:34 PM
Rombout Versluijs (rombout) added a comment.Jan 23 2019, 4:10 PM
Isnt it possible to calculate the total height of all panels in this view. Than if the height of the total is height than the window height, why not ONLY than activate the scrolling mechanism. Because when the panel isnt transparent or blocked by open panels, it would not be able to move the scene anyways.
If all panels are closed and its transparent, than void the scroll action. Sounds quite simple actually
William Reynish (billreynish) added a comment.Jan 23 2019, 10:08 PM
Yes, that's the idea. To only allow scrolling inside the area where you see panels, and make the input fall through to the underlying editor where the panels end.
