Maniphest T60589
Increase Area Splitting Action Zone Size
Closed, DuplicateDESIGN
Brecht Van Lommel (brecht)
Daniel Paul (DaPaulus)
Jan 17 2019, 10:34 AM
  • User Interface
Jacques Lucke (JacquesLucke)
William Reynish (billreynish)
This change D4033 makes it really difficult to drag the corners in the interface.
Especially with a tablet on a 4k monitor.
It was much faster to duplicate and reduce the windows before this change.
Please also consider to look at the horizontal and the vertical space it's also very small
https://blender.community/c/rightclickselect/K0cbbc/
At least an option for changing these scales/areas would be nice
Thanks for your hard work guys!
Daniel Paul (DaPaulus) created this task.Jan 17 2019, 10:34 AM
Daniel Paul (DaPaulus) updated the task description.Jan 17 2019, 10:39 AM
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).Jan 17 2019, 10:41 AM
The corner action zones were made smaller to avoid conflicting with buttons and controls inside the header. Before they would overlap. We could also increase the margin a bit to make a bit more space for this.
The edge grabbing zones could be made a bit larger I suppose.
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).Jan 17 2019, 10:45 AM
I guess the answer is the same as in T59856...
Question is how many complains are enough to change that again?
Brecht Van Lommel (brecht) closed this task as a duplicate of T59856: Splitting and merging viewports is much harder to achieve in 2.8.Jan 17 2019, 10:49 AM
Please reply in the existing task like D4033 or on devtalk, creating tasks here is not for user feedback.
William Reynish (billreynish) added a comment.EditedJan 17 2019, 10:52 AM
Just making them larger in itself is no good, because we received lots of reports before of users who were unable to click header buttons because the zones would overlap with buttons and controls, which is worse overall. You do have to be fairly precise, but at lease you won't accidentally split the window when just clicking buttons.
Only solution I can see is increasing header margin a bit to give it more space, or to just leave it.
Daniel Paul (DaPaulus) added a comment.Jan 17 2019, 10:57 AM
Sorry did not know that, did a new one because the task was closed.
