Maniphest T60647
regression - corruption of files
Closed, Duplicate
None
jan bauer (janb)
Jan 19 2019, 10:26 AM
  • BF Blender
  • BF Blender: Regressions
Brecht Van Lommel (brecht)
Jacques Lucke (JacquesLucke)
jan bauer (janb)
Philipp Oeser (lichtwerk)
William Reynish (billreynish)
Operating system: windows 10
Graphics card: RTX 2070
Broken: 8ba86020cc50
Worked: 2.79b
Saving a file with latest buildbots corrupt the files
  • Open the classroom scene from here https://download.blender.org/demo/test/classroom.zip (there are many version, this one definetly has the bug) with 2.8 or 2.7 buildbots,
  • save it,
  • reopen it and press F12, you will get kind of portal in the left corner of the room. Blender will also crash when rendering is finished, just before compositing.
Here is a screenshot before the crash:
Related Objects
Mentioned Here
T54504: Cycles Displacement node not automatically inserted in older files when linking
rB8ba86020cc50: GP: Display Stroke for Fill Alt mode always
jan bauer (janb) created this task.Jan 19 2019, 10:26 AM
William Reynish (billreynish) lowered the priority of this task from 90 to 50.Jan 19 2019, 5:11 PM
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).
Indeed, can confirm this. The classroom scene crashes every time it stops rendering, and is about to go to compositing.
jan bauer (janb) added a comment.Jan 19 2019, 6:34 PM
And the worst is how saving the file, even with the more stable 2.79 branch corrupts the files.
jan bauer (janb) added a project: BF Blender: Regressions.Jan 20 2019, 9:13 AM
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).Jan 23 2019, 12:51 PM
I cannot reproduce the crash.
Does the crash happen in the newest Blender 2.8 build, even when Render Samples is set to 1?
jan bauer (janb) added a comment.Jan 24 2019, 9:57 AM
@Jacques Lucke (JacquesLucke) if I don't save the file (use the original directly), it just hangs forever, but no crash anymore. I still have to kill as it will take 1 core of CPU forever(waited 5minutes at 25%) just after rendering. Actually, the crash was "better" as I didn't had to kill the process myself. It seems it's due to the compositing phase?
However, the file corruption when saving still happen with this strange portal being added in the left corner of the room.
jan bauer (janb) added a comment.Jan 24 2019, 10:02 AM
deactivating compositing deactivate the hang/crash, but strange "portal" still there anyway after saving:
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Jan 24 2019, 10:40 AM
that "portal" seems to be the dustbin object...
checking whats wrong with that...
Philipp Oeser (lichtwerk) added a comment.Jan 24 2019, 11:20 AM
dustBin's displacement in //assets/dustBin.blend on the rim object (called Cylinder) is making problems.
I assume this is still not using the 'new' displacement node in that file (it will be there when you open that file, but that is probably because cycles adds that automatically when seeing an old file)
And when linking, this automatic insertion fails, see T54504.
However, when I save dustBin.blend from 2.8 it should be there (also the material setting is set to bump only), so this is a bit puzzling...
[also not sure if the height should be fed from a normal? -- removing that connection solves the error, but gives different result of course...]
my 2 cents for the moment...
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
There's not really any corruption, just the same versioning issue as far as I can tell.
