Maniphest T60668
Bevel modifier breaks shape-key animation
Closed, Duplicate
None
Aaron Fjerstad (afjerstad)
Jan 20 2019, 1:21 PM
  • BF Blender
paul szajner (szap)
William Reynish (billreynish)
Operating system: Ubuntu 18.10
Graphics card: GeForce GTX 1050 Ti
Broken:
blender-2.80-b0dee09a6d55-linux-glibc224-x86_64
When the bevel modifier is on, shape key animations have no effect.
  1. Add a cube and subdivide it 10 times.
  2. Add the base shape-key.
  3. Add a second shape-key with a value of 0 and select it.
  4. In edit mode, use "To Sphere" to make the cube a sphere.
  5. Go back into object mode and observe that adjusting the second shape-key slider between 0 and 1 transitions the shape from cube to sphere.
  6. Keyframe the slider to 0 at frame 1 and keyframe it to 1 at frame 30.
  7. In object mode, observe that moving across the timeline between frames 1 and 30 changes the shape of the cube to a sphere.
  8. Select the base shape-key and set the second shape-key slider value to 0.
  9. Add a bevel modifier.
  10. Select the second shape-key and observe that the shape immediately changes to a sphere despite the aforementioned slider being at 0.
  11. Observe that sliding the slider does nothing.
  12. Observe that nothing happens when you move the timeline.
Aaron Fjerstad (afjerstad) created this task.Jan 20 2019, 1:21 PM
Aaron Fjerstad (afjerstad) updated the task description.
Aaron Fjerstad (afjerstad) updated the task description.Jan 20 2019, 1:24 PM
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).Jan 20 2019, 1:51 PM
Can you make an example blend file that demonstrates this? Thanks.
paul szajner (szap) added a subscriber: paul szajner (szap).Jan 20 2019, 6:14 PM
you can look here for a test .blend, some other modifier behave the same way : https://developer.blender.org/T60067
William Reynish (billreynish) lowered the priority of this task from 90 to 50.Jan 20 2019, 6:58 PM
William Reynish (billreynish) added a subscriber: Campbell Barton (campbellbarton).
Ok, I can reproduce that.
@Campbell Barton (campbellbarton): Who to assign this to?
Jacques Lucke (JacquesLucke) closed this task as a duplicate of T60067: some modifier doesn't take shape keys information correctly.Jan 29 2019, 3:43 PM
