Maniphest T60700
Sculpt: wireframe shows triangulated
Closed, Resolved
Clément Foucault (fclem)
ALEXEY KOVALENKO (kovalex)
Jan 21 2019, 5:52 AM
  • BF Blender
  • Sculpt, Paint & Texture
  • EEVEE & Viewport
Alex (SpectreFirst)
Carlos del Olmo (GDO)
Daniele Viagi (d.viagi)
Demeter Dzadik (Mets)
EVGENIJ (anion)
4 More Subscribers
Tokens
"Like" token, awarded by Mets.
I mean not physically triangulating but only in viewport
https://gyazo.com/aba287453ba938bdb5523871bce15942
In 2.79 I can see polygons without triangulating in sculpt mode
https://gyazo.com/9b815afa3c411b460e6015a462226d7e
ALEXEY KOVALENKO (kovalex) created this task.Jan 21 2019, 5:52 AM
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 50.Jan 21 2019, 1:50 PM
Jacques Lucke (JacquesLucke) added subscribers: Clément Foucault (fclem), Jacques Lucke (JacquesLucke).
Is there any good reason for this behavior, @Clément Foucault (fclem)? (except performance maybe?)
ALEXEY KOVALENKO (kovalex) added a comment.Jan 21 2019, 1:58 PM
I use move brush for tweaking my retopologed model and proper view of topology is necessery for control quality of model. But triangulate mode destroy this work
Demeter Dzadik (Mets) awarded a token.Jan 22 2019, 1:38 AM
Demeter Dzadik (Mets) added a subscriber: Demeter Dzadik (Mets).Jan 22 2019, 1:41 AM
Even if it does increase performance, there should be an option to turn it off and go for the less performant quad display because this makes the sculpt tools a pain to use on low poly models, which I think is common enough use case, and it is a use case where performance is not that big a concern.
Harold Tovar (haroldgrafico) added a subscriber: Harold Tovar (haroldgrafico).EditedJan 22 2019, 4:16 PM
Hi there Devs!!
First of all thank you so much for making Blender awesome everyday :)
Secondly I was about to report this and then I found it here so I'm having the same issue, it would be helpful to have an option to show quads in Sculpt Mode because in my case I used to use sculpt mode for tweaking topology and to adjust volumes, specially after the retopology process and is easier to do this process in Sculpt Mode rather in Edit mode because you can take advantage of some brushes like grab, inflate, smooth and so on for adding volume and refining geometry :)
Hopefully you can bring us a way to solve this issue
Thank you so much
Sorry in advance for my bad English
ALEXEY KOVALENKO (kovalex) added a comment.Jan 22 2019, 5:09 PM
Yes guys, only one invisible checkerbox) Be sure users and Harold with me will say big thanks for your attention to details) And f course thanks for amazing 3D soft ever!
Philipp Oeser (lichtwerk) assigned this task to Clément Foucault (fclem).Apr 2 2019, 10:48 AM
Philipp Oeser (lichtwerk) added a project: GPU / Viewport.
Philipp Oeser (lichtwerk) mentioned this in T63192: Sculp Mode in Wireframe show the mesh in triangles.
Philipp Oeser (lichtwerk) merged a task: T63192: Sculp Mode in Wireframe show the mesh in triangles.
Philipp Oeser (lichtwerk) added subscribers: Carlos del Olmo (GDO), Philipp Oeser (lichtwerk).
EVGENIJ (anion) added a subscriber: EVGENIJ (anion).May 21 2019, 9:50 AM
Brecht Van Lommel (brecht) renamed this task from Triangulated polygons in Sculpt Mode to Sculpt: wireframe shows triangulated.May 29 2019, 3:32 PM
Germano Cavalcante (mano-wii) merged a task: T67302: Triangulated wireframe in sculptmode.Jul 22 2019, 3:57 PM
Germano Cavalcante (mano-wii) added subscribers: Daniele Viagi (d.viagi), Alex (SpectreFirst), ronan ducluzeau (zeauro).
William Reynish (billreynish) merged a task: T67721: Triangles in Sculpt Mode without Dyntopo.Jul 26 2019, 12:50 PM
William Reynish (billreynish) added a subscriber: Lindy (Enalya).
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Resolved.Dec 16 2019, 2:24 PM
This was resolved in 2.81 already.
Will close as resolved, but everyone feel free to comment again if issues persist in 2.81 upwards...
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed GPU / Viewport.Jun 19 2020, 11:08 PM
