Maniphest T60705
EEVEE Volumetrics not working
Closed, Resolved
Clément Foucault (fclem)
Daniel (elkoled)
Jan 21 2019, 9:31 AM
  • BF Blender
  • EEVEE & Viewport
Daniel (elkoled)
Philipp Oeser (lichtwerk)
Operating system:
Windows 7 64 bit
Intel Core i5 6300U (with Intel HD520)
blender 2.80 dd3f5186260e, 21.01.2019
Volumetrics on default cube shows only black cube and yellow-grey background with glitches on the edges on camera movement.
Clean install of blender, no addons.
  1. Assign principled volume shader to default cube
  2. Enable volumetrics in eevee settings
  3. Switch to rendered view
Screenshot:
.blend file
Thank you all for your work. I love blender.
Related Objects
Mentioned Here
rBdd3f5186260e: Cleanup: rename GPU function to set buffer length
Daniel (elkoled) created this task.Jan 21 2019, 9:31 AM
Philipp Oeser (lichtwerk) assigned this task to Clément Foucault (fclem).Jan 21 2019, 11:20 AM
Philipp Oeser (lichtwerk) added subscribers: Clément Foucault (fclem), Philipp Oeser (lichtwerk).
Cannot reproduce here (Fedora 29, 970m with 410.78 drivers)
Shot in the dark, but does running blender from the commandline with the --debug-gpu-force-workarounds option help here?
(Please also attach the output of that as a .txt file here...)
@Clément Foucault (fclem): does this ring a bell?
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to Normal.Jan 21 2019, 11:21 AM
Clément Foucault (fclem) added a comment.Jan 21 2019, 11:38 AM
Windows 7 64 bit
This is the issue. The drivers for win 7 are old and no more maintained. So we find all these kind of issues on theses drivers.
Can you make sure your drivers are at least at version 15.45.23.4860 ?
These drivers are also one year old and even the Win10 drivers fixed core issues only a few month ago.
Daniel (elkoled) added a comment.EditedJan 21 2019, 11:47 AM
In T60705#603369, @Clément Foucault (fclem) wrote:
Windows 7 64 bit
Thanks for the reply.
--debug-gpu-force-workarounds still shows the glitch.
My dxdiag panel is attached.
Clément Foucault (fclem) added a comment.Jan 21 2019, 11:54 AM
Well the versioning seems strange. Your driver is said to be 2 years old. But the last available on intel driver page says it's only one year old. Try updating your drivers.
Daniel (elkoled) changed the task status from Unknown Status to Resolved.Jan 21 2019, 12:53 PM
Updated drivers and works fine now! Thanks for your help.
I found out, that this is a device specific driver (LenovoT460 Laptop), thats why the version number is different.
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed Eevee.Jun 19 2020, 11:08 PM
