Maniphest T60726
Crash after 10 seconds
Closed, Archived
Jacques Lucke (JacquesLucke)
george martin (Junior15)
Jan 21 2019, 11:23 PM
  • BF Blender
Philipp Oeser (lichtwerk)
I just downloaded Blender 2.79 and tried to start it. Once i start it i could only use the program for only 10 seconds before it crashes. I have a MSI Windows 10 laptop and it has a lot of storage because i just started using my laptop since last month, so it doesnt have so much on it for the storage usage. i deleted blender and re-downloaded to see if it happens again and it still does the same thing. If anyone could tell me why this happens, please tell me because i want to teach myself the basic 3D animations so i could proceed and work hard to get a career of it
Related Objects
Duplicates Merged Here
T60765: Crashing error
george martin (Junior15) created this task.Jan 21 2019, 11:23 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Jan 22 2019, 10:59 AM
This is not enough information to proceed:
Philipp Oeser (lichtwerk) merged a task: T60765: Crashing error.Jan 23 2019, 11:18 AM
Philipp Oeser (lichtwerk) added a comment.Jan 23 2019, 11:21 AM
Please give us the information needed (no need to open another report)
Here are some other things you could try:
  • Give us your exact Blender, OS and GPU (including drivers) versions, as requested in the template!
  • Ensure both your OS and drivers are fully up-to-date (and use official GPU drivers, not those provided by windows or tablet/laptop maker).
  • Try to disable any running antivirus.
  • Ensure you have no python executable available in your %path% envvar.
  • Try the latest build from our buildbot (builder.blender.org).
  • Try to start Blender in factory settings (--factory-startup commandline option) (this will ensure whether this is a userpref or addon issue or not).
  • Try to tweak your GPU driver settings (e.g. try different values between 'performance' and 'quality' if you have such slider, etc.).
  • Launch Blender from the command line with -d option and attach as text file here any error printed out in the console (do not paste it directly in comment).
  • Try to run Blender through Software OpenGL, this will be much slower however, if everything works then it means that the bug is spefic for your GPU/Driver and you should report the bug to your GPU vendor instead. On MS-Windows: Download this dll and copying it so its located in the same directory as 'blender.exe' and run Blender normally.
Philipp Oeser (lichtwerk) renamed this task from Error to Crash after 10 seconds.Jan 23 2019, 11:22 AM
Philipp Oeser (lichtwerk) updated the task description.
Jacques Lucke (JacquesLucke) changed the task status from Unknown Status to Unknown Status.Mar 14 2019, 5:18 PM
Jacques Lucke (JacquesLucke) claimed this task.
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).
