Maniphest T60776
Keymaps added from python doesn't behave correctly.
Closed, Resolved
Brecht Van Lommel (brecht)
Jean Da Costa (jeacom256)
Jan 23 2019, 12:13 AM
  • BF Blender
Jacques Lucke (JacquesLucke)
Operating system: Windows 7
Graphics card: Nvidia geforce 1050
Broken: 7f40d553f903
A keymap added from python to call a custom menu makes the menu behaves incorrectly.
The menu requires a double click in order to activate any entrie
use the default cube scene
go to edit mode
paste and run this code on text editor:
press Alt + W to activate the custom menu,
in principle, it might look ok but if you try to select an option, it requires a second click (which shouldn't).
import bpy
from bpy.types import Menu
# spawn an edit mode selection pie (run while object is in edit mode to get a valid output)
class VIEW3D_PIE_template(Menu):
    # label is displayed at the center of the pie menu.
    bl_label = "Select Mode"
    def draw(self, context):
        layout = self.layout
        pie = layout.menu_pie()
        # operator_enum will just spread all available options
        # for the type enum of the operator on the pie
        pie.operator_enum("mesh.select_mode", "type")
def register():
    km = bpy.context.window_manager.keyconfigs.addon.keymaps.new(name="3D View", space_type="VIEW_3D")
    kmi = km.keymap_items.new("wm.call_menu_pie", type="W", alt=True, value="PRESS")
    kmi.properties.name = "VIEW3D_PIE_template"
    bpy.utils.register_class(VIEW3D_PIE_template)
if __name__ == "__main__":
    register()
Related Objects
Mentioned In
T60850: Emulate 3 button mouse couses weird behavior in UI
Mentioned Here
rB0b37399cbe24: Fix T60790, T60636, T60631: MMB emulation issues after recent changes.
rB7f40d553f903: Cleanp: use single global for draw manager
Jean Da Costa (jeacom256) created this task.Jan 23 2019, 12:13 AM
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 30.Jan 23 2019, 11:42 AM
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).
Seems to work as expected here. Can you upload a short .gif to show the issue?
Jean Da Costa (jeacom256) added a comment.Jan 23 2019, 4:00 PM
@Jacques Lucke (JacquesLucke) It turns out that this problem is being caused by the emulate 3 button mouse option,
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Jan 25 2019, 12:00 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Already solved in rB0b37399cbe24: Fix T60790, T60636, T60631: MMB emulation issues after recent changes..
