Maniphest T60811
Blender crashes when i click on it from task bar and when i open from minimized or go back to the application
Closed, Resolved
Brecht Van Lommel (brecht)
Nicholas (DedosThreat)
Jan 24 2019, 5:51 AM
  • BF Blender
Joshua Leung (aligorith)
Ray Molenkamp (LazyDodo)
Operating system: Microsoft Windows 10 (build 17134), 64-bit
Graphics card: Intel(R) UHD Graphics 620
Processor: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
Broken:
2.79b release
(ive been using blender for a couple years and i stopped for like 4 months and when i came back to it, this happened, i tried reinstalling and removing files but nothing has worked..)
Revisions and Commits
rB Blender
Nicholas (DedosThreat) lowered the priority of this task from 90 to Normal.Jan 24 2019, 5:51 AM
Nicholas (DedosThreat) created this task.
Brecht Van Lommel (brecht) triaged this task as 90 priority.Jan 24 2019, 7:33 AM
Brecht Van Lommel (brecht) edited projects, added BF Blender; removed Add-ons (Community).
Nicholas (DedosThreat) added a comment.Jan 24 2019, 5:04 PM
I need this really fast if anyone knows a solution..
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).Jan 24 2019, 5:07 PM
See the advice here about installing latest drivers:
https://docs.blender.org/manual/en/dev/troubleshooting/gpu.html
Other than that it's unclear what the cause could be.
Nicholas (DedosThreat) added a comment.Jan 24 2019, 5:53 PM
I tried that :(
Nicholas (DedosThreat) added a comment.Jan 24 2019, 8:58 PM
Im going to try resetting my pc
Joshua Leung (aligorith) added a subscriber: Joshua Leung (aligorith).Jan 25 2019, 2:58 PM
This sounds like a graphics driver bug. I used to have similar issues about a decade ago on my old desktop that had integrated graphics (and it wasn't even one by Intel back then). The only solutions I found for that were:
  1. Don't minimise Blender windows ever and/or don't keep Blender open if you're going to be away from the screen for a while (e.g. if the screensaver might pop up, or the machine might go into standby),
  2. Save work before switching away from Blender,
  3. Disable cursor shadows (this helped with some weird cursor flickering issues when moving over the UI, and also improved interactivity)
In your case, I'd suggest to try adjusting each one of the other options in the Advanced System Performance section one by one, taking note of whether disabling certain things makes Blender more stable
In particular I'd probably start by disabling Peek and any fancy visual effects for windows (e.g. animation, shadows, transparency, etc.)
Nicholas (DedosThreat) added a comment.Jan 25 2019, 3:31 PM
I just reset my PC and it's working perfectly now :')
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Jan 25 2019, 7:28 PM
Let's consider it resolved then, not much we can do here to investigate things further.
Nicholas (DedosThreat) lowered the priority of this task from 90 to Normal.Feb 6 2019, 2:59 PM
So after i reset my Computer i found out what the problem was, it was my XP-pen drivers, its been causing this so, if anyone has a fix that would be great :) otherwise i just cant use my pen tablet.
Nicholas (DedosThreat) claimed this task.Feb 6 2019, 5:29 PM
Brecht Van Lommel (brecht) added a comment.Feb 6 2019, 5:34 PM
Does it also happen with the latest daily builds (2.79 or 2.80)?
https://builder.blender.org/download/
We recently made some changes to tablet handling which might help here.
Brecht Van Lommel (brecht) removed Nicholas (DedosThreat) as the assignee of this task.Feb 6 2019, 5:34 PM
Nicholas (DedosThreat) added a comment.Feb 6 2019, 7:06 PM
The Beta?
Brecht Van Lommel (brecht) added a comment.Feb 6 2019, 7:07 PM
Both the 2.79 stable daily build and the 2.80 beta have new fixes compared to 2.79b.
Nicholas (DedosThreat) added a comment.Feb 6 2019, 8:52 PM
Works perfectly! thanks! ill tell you if it acts up again ?
Nicholas (DedosThreat) triaged this task as High priority.Feb 7 2019, 3:20 PM
I just was using blender today and its doing the same thing. it didnt fix the pen tablet software ;-;
Brecht Van Lommel (brecht) added a commit: rB6fdc688cd06c: Windows: refactor GHOST wintab handling..Feb 7 2019, 3:50 PM
Brecht Van Lommel (brecht) changed the task status from Resolved to Unknown Status.Feb 7 2019, 3:51 PM
Brecht Van Lommel (brecht) lowered the priority of this task from High to 30.
Did you try 2.79 or 2.80?
Please try tomorrow's 2.79 build, it will include a possible fix for this issue.
Nicholas (DedosThreat) added a comment.Feb 10 2019, 6:50 PM
Still not working :(
Nicholas (DedosThreat) raised the priority of this task from 30 to High.Feb 11 2019, 7:44 PM
Brecht Van Lommel (brecht) raised the priority of this task from High to 90.Feb 11 2019, 7:48 PM
Brecht Van Lommel (brecht) added a subscriber: Ray Molenkamp (LazyDodo).
Nicholas (DedosThreat) added a comment.Apr 4 2019, 4:21 PM
Wow i forgot about this, thanks.
Brecht Van Lommel (brecht) added a comment.Apr 4 2019, 4:22 PM
For blender_debug_log.cmd, those are included in the latest daily 2.80 builds. You just run them from the same folder as blender.exe.
Nicholas (DedosThreat) added a comment.Apr 4 2019, 4:40 PM
i restarted my pc and the beta is working now
but i really wanted the other version to work because im used to the interface
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Apr 4 2019, 5:53 PM
It's unlikely we will backport the new pen system to 2.79, all focus is on 2.80 now.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Apr 4 2019, 5:53 PM
