Maniphest T60835
Material, Render bugs
Closed, Archived
Brecht Van Lommel (brecht)
Pavlo Leskovych (pleskovych)
Jan 24 2019, 9:06 PM
  • BF Blender
  • Cycles
  • Render Pipeline
Abram (AbramD)
Philipp Oeser (lichtwerk)
Operating system:Windows 10
Graphics card:
MSI GTX 1050TI 4gb
Processor: AMD Ryzen 2600
Broken:
2.80, e5e885d0ecb9, blender2.8, 2018-12-23
I'm newbie in modelling. But when I switch to solid, or material mode. My model is rendering correctly, the same in rendered mode using EEVEE. But when I started baking materials in cycles toolbar, after that I mentioned artifacts in rendered and material modes, same in render images.
All files uploaded.
Related Objects
Pavlo Leskovych (pleskovych) created this task.Jan 24 2019, 9:06 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Jan 25 2019, 11:58 AM
Textures are missing (please reupload your file with packed textures...)
Anyways: is this still happening when you unplug the Vector Displacement node?
Or you a regular Displacement node (not sure if you are using a texture suited for vector displacement...)?
Marking as incomplete for now...
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Jan 25 2019, 7:17 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
What happens is that Cycles is doing actual displacement of the mesh vertices. You can fix this by going to Material > Settings > Displacement Method and using Bump Only.
We have recently changed the default to Bump Only to solve this confusion.
Brecht Van Lommel (brecht) merged a task: T60882: Some kind of glitch.Jan 25 2019, 10:13 PM
Brecht Van Lommel (brecht) added a subscriber: Abram (AbramD).
