Maniphest T60850
Emulate 3 button mouse couses weird behavior in UI
Closed, Resolved
Brecht Van Lommel (brecht)
Lubomir Cenovsky (lubomircenovsky)
Jan 25 2019, 8:53 AM
  • BF Blender: 2.8
Jean Da Costa (jeacom256)
William Reynish (billreynish)
Operating system: Ubuntu 16.04
Graphics card: GTX 680
Broken: 2.8, 7467049055a7
When I have enabled option emulate 3 button mouse, UI on all different places behaves weirdly. Sometimes I have to click twice to confirm selection and sometimes sigle click trigers click and drag action. This happends in 3D viewport, outliner, node editor etc. For example (I'm using right click select) if I have two object overlaping each other, and I use Alt + Right click to invoke select menu, where i can choose which object I want to select, to confirm selection I have to click twice. Doesn have to be double click (meaning two quick clicks). And this bahevior appears everywhere but with different behavior. In outliner when I want to change visibility for example, sometimes it clicks and grags ... meaning I am selecting visibility icons ion multiple objects. In node editor I want to change value of slider, after single click is invoked click and drag action.
Most consistent way to reproduce this bavior is having active options Right click select and Emulate 3 button mouse. Then add two object overlaping each other (Monkey and Cube for example). Alt + Right click to invoke selection menu. To confirm selection it's needed to click twice. Without Emulate 3 butt.m. this behaves normaly.
Related Objects
Mentioned Here
rB0b37399cbe24: Fix T60790, T60636, T60631: MMB emulation issues after recent changes.
T60776: Keymaps added from python doesn't behave correctly.
rB7467049055a7: 3D View: add back initial clipping support
Lubomir Cenovsky (lubomircenovsky) created this task.Jan 25 2019, 8:53 AM
Jean Da Costa (jeacom256) added a subscriber: Jean Da Costa (jeacom256).EditedJan 25 2019, 9:26 AM
It seems related: T60776
William Reynish (billreynish) lowered the priority of this task from 90 to 30.Jan 25 2019, 10:19 AM
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).
This was fixed about a day ago. Please try with a newer build.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Jan 25 2019, 12:01 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Already solved in rB0b37399cbe24: Fix T60790, T60636, T60631: MMB emulation issues after recent changes..
