When rendering a sequence of frames using Freestyle, the lines from the current frame are rendered and place over every frame in the sequence.
Blender 2.8
Date 2019-01-24 01:12
Hash: 1d908bffddb4
Steps to reproduce:
- Load Factory Settings
- Set the timeline to 2 frames
- With the timeline marker at Frame 1, select the camera and add a LocRot key by pressing I
- Move the timeline to Frame 2.
- Rotate around the default Cube and Align Camera to View by pressing Ctrl+Alt+0
- With the camera still selected, add a LocRot key by pressing I
- In the Render tab, select Freestyle
- In the Output tab, select a file location for rendered output
- Move the timeline marker to Frame 1
- Render the Animation
Result:
The lines from frame 1 carry over and are rendered on top of frame 2.
Frame 1:
Frame 2:
Additionally, if the timeline marker is set to Frame 2, the lines from Frame 2 are carried over and rendered on top of the other frame. The lines are only rendered from where the current timeline marker is set.
Expected Result:
Each frame is rendered with its own unique lines.
System Info:
OS: Windows 10 Education
Graphics Card: NVIDIA GeForce GTX 1070
