Maniphest T60888
UI Italian translation applied in Preferences freezes Blender 2.8b on quit or discard changes
Closed, Archived
Sebastian Parborg (zeddb)
Cristian Palmas (Cristian.Palmas)
Jan 26 2019, 12:06 PM
  • BF Blender
  • Translations
  • User Interface
Operating system: Kubuntu 16.04.3 LTS 64bit
Graphics card:
renderer:	'GeForce GTX 960M/PCIe/SSE2'
vendor:		'NVIDIA Corporation'
version:	'4.5.0 NVIDIA 415.27'
Broken: 2.80 (sub 42), branch: blender2.7, commit date: 2019-01-25 23:33, hash: 1b6da95ccb11, type: Release
build date: 2019-01-26, 00:26:16
Setting Italian translation for Interface, New data and Tooltips makes the os freeze and the only option is brutal power off
Related Objects
Mentioned Here
rB1b6da95ccb11: Cleanup: avoid static vars to store legacy shaders
Cristian Palmas (Cristian.Palmas) created this task.Jan 26 2019, 12:06 PM
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Feb 1 2019, 2:51 PM
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
I can't reproduce this on my end. Is this still and issue for you with the latest blender beta?
Cristian Palmas (Cristian.Palmas) added a comment.Feb 1 2019, 7:28 PM
I downloaded the beta version 8a51af7d1c98, I will see tomorrow if the bug is still there.
Cristian
Cristian Palmas (Cristian.Palmas) added a comment.Feb 2 2019, 8:04 PM
The problem still persists on branch 141c6073ca39
Sebastian Parborg (zeddb) added a comment.Feb 4 2019, 10:56 AM
Can you attach the output (as a file) when you run blender with --debug ?
Cristian Palmas (Cristian.Palmas) added a comment.Feb 4 2019, 1:38 PM
What kind of output do you need? That in the terminal after running ./blender --debug? Or something else?
Sebastian Parborg (zeddb) added a comment.Feb 4 2019, 2:22 PM
Yes, I need the terminal output that you get when you run with the debug flag and make blender freeze.
Because you need to restart the computer, you could do ./blender --debug &> output.txt and get the output saved in a file that you can attach here.
Cristian Palmas (Cristian.Palmas) added a comment.Feb 4 2019, 7:57 PM
Here is the output
Sebastian Parborg (zeddb) added a comment.Feb 4 2019, 8:16 PM
Does this happen if you run the bundled blender-softwaregl instead?
Cristian Palmas (Cristian.Palmas) added a comment.EditedFeb 4 2019, 8:22 PM
No, it works but unfortunately the software is really slow. When scaling and grabbing, for example, the cube moves jerkily. Infact, it is very slow even without translation applied.
I didn't yet test the latest branch published today.
Sebastian Parborg (zeddb) changed the task status from Unknown Status to Unknown Status.Feb 4 2019, 8:31 PM
Sebastian Parborg (zeddb) claimed this task.
So this is a driver issue and not a blender issue then.
There is sadly not much we can do in this case as the issue is not on our end.
Maybe this works in newer kubuntu releases as users have reported issues when running older releases. But there is no guarantee that updating will solve this.
