Maniphest T60939
Change in the definition of the line of a Stroke when adding more than one Fill with active Clamp.
Closed, Duplicate
None
Juan Camardella (AnimBlenders)
Jan 28 2019, 1:42 AM
  • BF Blender
  • Grease Pencil
Antonio Vazquez (antoniov)
Clément Foucault (fclem)
Frederic Lierman (FredLierman)
Sebastian Parborg (zeddb)
Tokens
"Love" token, awarded by FredLierman.
Operating system: Ubuntu Studio 18.04 64 bits
Graphics card: GeForce GTX 970
Broken: 2.80, 25772c9e1d2d, blender2.8, 2019-01-26
Change in the definition of the line of a Layer of a Stroke, from soft to hard when adding more than one Fill with active Clamp, located above the first Layer with Line.
In 2D Animation create a Grease Pencil object, draw a Stoke with Line (plus Fill, too) in a first Layer, in a second Layer create another Stoke with Fill in another material. And in a third Layer another Stoke with Fill with another different material. Activating the Clamp of the second Layer changes the definition of the Line of the first Layer from soft to hard (pixelated). If the Clamp of the third Layer is activated, it also happens, but if the third Layer is hidden by activating the Visibility icon, the line becomes smooth even with the second layer with the Clamp activated.
Related Objects
Mentioned Here
rB25772c9e1d2d: Fix T59921: RuntimeError:bpy.ops.object.gpencil_modifier_apply()
Juan Camardella (AnimBlenders) created this task.Jan 28 2019, 1:42 AM
Juan Camardella (AnimBlenders) updated the task description.Jan 28 2019, 2:11 AM
Antonio Vazquez (antoniov) added a subscriber: Antonio Vazquez (antoniov).Jan 28 2019, 9:45 AM
What do you mean with clamp? Could you paste a screenshot of the parameter?
Juan Camardella (AnimBlenders) added a comment.Jan 28 2019, 11:32 PM
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Jan 29 2019, 5:44 PM
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
@Antonio Vazquez (antoniov) do you need more information?
Antonio Vazquez (antoniov) added a subscriber: Clément Foucault (fclem).Jan 29 2019, 5:46 PM
@Sebastian Parborg (zeddb) No. I have seen the problem: Antialiasing when mix layers. It's a general problem that we need fix with @Clément Foucault (fclem).
Sebastian Parborg (zeddb) assigned this task to Antonio Vazquez (antoniov).Jan 29 2019, 6:16 PM
Sebastian Parborg (zeddb) raised the priority of this task from 30 to 50.
I'll mark this as confirmed then. Because I can't assign multiple people, I'll assign you. You can reassign to fclem if you think that would be better.
Frederic Lierman (FredLierman) awarded a token.Feb 9 2019, 5:19 AM
Frederic Lierman (FredLierman) added a subscriber: Frederic Lierman (FredLierman).
Dalai Felinto (dfelinto) removed Antonio Vazquez (antoniov) as the assignee of this task.Dec 23 2019, 4:35 PM
Dalai Felinto (dfelinto) added a project: Tracker Curfew.
Antonio Vazquez (antoniov) closed this task as a duplicate of T66293: GPencil: Redesign Blend modes and cleanup Drawing Engine.Dec 28 2019, 9:55 AM
Antonio Vazquez (antoniov) removed a project: Tracker Curfew.
