Operating system: SUSE Leap 15.0
Graphics card: NVidia GTX 560ti (official drivers)
Broken: 2.80, 5632e1b52586, x86_64 linux, 2019-01-24 (buildbot)
Compositor RGB Curves node gives false colours when set to 'Film like' and when any of R,G,B channels are adjusted. Adjustment of C channel alone is OK.
sidenote; Constant hue adjustment is definitely an interesting feature to have! But since film often has various hue shifts going on, if anything, 'Standard' is possibly closer with a typical S-curve - a bias to cyan, magenta, yellow in the highlights corresponding to the curve shoulder.
'Hue hold' or 'Hue lock' could be alternative names.
Example .blend
Load attached .blend, render.
Ref:
https://developer.blender.org/rB4de7c0c3105a80d244dd9f2078c310331873a16b
Notes:
- Muting the noise texture hides the issue in this example.
- Stepping through the emission strength from 0.0 to 1.0 gives varying results. Might be a clue to the cause?
