Maniphest T61046
Cloth from Blender 2.79 project file doesn't bake properly in blender 2.80 (Object Constraint Problem?)
Closed, Resolved
Sergey Sharybin (sergey)
shaun (toxsickcity)
Jan 31 2019, 2:52 AM
  • BF Blender
  • Physics
Bastien Montagne (mont29)
Sebastian Parborg (zeddb)
shaun (toxsickcity)
Hi,
I am trying blender 2.80 26-01-2019 25772c9e1d2d
Just also tried 2019-01-31 8c8979067490
I have a project that was created in 2.79 and tried opening it in 2.80 and the cloth are all stuffed up.
One of the cloth works fine but the other is not really moving. I tried rebaking in 2.80 but it appears very broken.. (Cloth stays rigid in my project rebaking)
It might be something to do with having the cloth copy location of a bone. I am not 100% sure
I have created two tests for you to look over. Both Created in 2.79
test1.zip two soft balloons moving and shaking
test2.zip One with a sheet going over the box
in blender 2.79 both projects play fine and bake fine
in blender 2.80 both projects fail at baking.. the mesh goes crazy and jumps all over the place.
in blender 2.80 it seems to be the object constraint is moving every subframe as playback kind of mimics this statement. for the tests..
(https://drive.google.com/open?id=1SWdWCpBXza4nRMxroJjspBa5oRXuxs_e)
I am under the impression that the problem above is similar as my Main Project problem.
The project was too large to share.. sorry.. I hope my test files above help to solve the problem for me.
Revisions and Commits
rB Blender
shaun (toxsickcity) created this task.Jan 31 2019, 2:52 AM
shaun (toxsickcity) renamed this task from Cloth from Blender 2.79 project file doesn't bake properly in blender 2.80 to Cloth from Blender 2.79 project file doesn't bake properly in blender 2.80 (Object Constraint Problem?).Jan 31 2019, 3:56 AM
shaun (toxsickcity) updated the task description.
shaun (toxsickcity) updated the task description.Jan 31 2019, 4:01 AM
shaun (toxsickcity) added a project: BF Blender.Jan 31 2019, 4:24 AM
shaun (toxsickcity) added a project: Physics.
Sebastian Parborg (zeddb) assigned this task to Sergey Sharybin (sergey).Jan 31 2019, 1:22 PM
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
Might be related to (or dup of) T60836
Bastien Montagne (mont29) removed Sergey Sharybin (sergey) as the assignee of this task.Jan 31 2019, 3:03 PM
Bastien Montagne (mont29) raised the priority of this task from 50 to 90.
Bastien Montagne (mont29) updated the task description.
Bastien Montagne (mont29) added a subscriber: Sergey Sharybin (sergey).
Sebastian Parborg (zeddb) assigned this task to Sergey Sharybin (sergey).Jan 31 2019, 3:31 PM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).Jan 31 2019, 4:30 PM
@Sebastian Parborg (zeddb) sorry, looks like phab does not warn when you are saving updated description, that someone else changed the task in-between ;)
Bastien Montagne (mont29) added a comment.Jan 31 2019, 4:31 PM
This is also probably same general issue as T60451
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved by committing rB9d10fc13e770: Fix T61046: Object with cloth jumps around.Jan 31 2019, 5:39 PM
Sergey Sharybin (sergey) added a commit: rB9d10fc13e770: Fix T61046: Object with cloth jumps around.
shaun (toxsickcity) added a comment.Feb 1 2019, 4:53 AM
I Can Verify that the New Nightly Build of 2.80
the cloth tests above are solved.
My Main project is also working properly now.
Thanks so much for the effort guys..
Cheers
