Maniphest T61081
Some transform modes don't apply absolute grid snaping
Confirmed, LowTO DO
Jonathan (Computercrack)
Jan 31 2019, 11:57 PM
  • BF Blender
  • Modeling
Sebastian Parborg (zeddb)
Tokens
"Love" token, awarded by bnzs.
Operating system: Windows 10
Graphics card: GTX 1080 ti
Broken:
Blender 2.8 January 31, 01:48:40 - 8c8979067490 Beta
Blender 2.79 (It worked)
Blender 2.77 (It worked)
Absolut grid snaping dont work with "Face Inset" and neither with loop cuts.
Turn on the snaping (increment) -> turn on absolut grid snaping -> spawn a plane -> try to snap while loop cutting or inseting faces.
Jonathan (Computercrack) created this task.Jan 31 2019, 11:57 PM
Sebastian Parborg (zeddb) assigned this task to Campbell Barton (campbellbarton).Feb 1 2019, 12:02 PM
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
This doesn't seem to be related to absolute grid snap. For me even normal snapping is off when you use loop cup of face inset.
I can toggle it on in loop cut by holding ctrl or doing shift+tab, but this doesn't work with face inset.
Jonathan (Computercrack) added a comment.Feb 1 2019, 9:22 PM
Exactly! I also experienced that the face inset isn't even anymore. If I tried to inset for example a rectangle the space on the top and bottom is smaller then the space on right and left side. I switched back to .79 to try it and there it works.
I can work around it but I thought it would help report it.
Campbell Barton (campbellbarton) renamed this task from Absolute Grid Snaping to Some transform modes don't apply absolute grid snaping .May 1 2019, 1:48 AM
Campbell Barton (campbellbarton) lowered the priority of this task from 50 to Low.
Campbell Barton (campbellbarton) mentioned this in T63731: Modeling Module.
Campbell Barton (campbellbarton) edited a custom field.
Campbell Barton (campbellbarton) added a comment.May 1 2019, 1:52 AM
Tested 2.79 and loop cut isn't absolute-grid snapping, this is a TODO.
B (bnzs) awarded a token.Aug 26 2019, 9:12 PM
Germano Cavalcante (mano-wii) mentioned this in T68836: Transform Refactoring.Apr 3 2020, 9:48 PM
Campbell Barton (campbellbarton) added a project: Modeling.Jun 17 2020, 5:05 AM
Campbell Barton (campbellbarton) moved this task from Backlog to Todo (Transform) on the Modeling board.
