Maniphest T61119
Sculpt mode ignores shape key when the object has a Mask modifier.
Closed, Resolved
Sergey Sharybin (sergey)
Demeter Dzadik (Mets)
Feb 2 2019, 12:24 AM
  • BF Blender
Brecht Van Lommel (brecht)
Sebastian Parborg (zeddb)
Broken: 2.80, a1ae04d15a9f
If your object has Mask modifier, entering sculpt mode on a shape key will ignore any existing data in that shape key. It will be as if you are sculpting a brand new shape key. When you leave sculpt mode, the "fake" shape key you've been sculpting will be added onto the actual shape key that you were meant to be sculpting.
Also note that the vertex group that is specified for the Mask modifier must have some verts assigned to it to produce the bug, even if the assigned weights are 0. The bug doesn't happen if no vertex group is selected.
  • Download attached blend
  • Note how the currently active shape key turns the cube into a sphere.
  • Enter sculpt mode
  • The mesh turns back into a cube (as if the shape key didn't exist)
Workaround
Disabling the mask modifier while sculpting makes the problem go away.
I noticed this warning on the modifier when entering sculpt mode
But note that this warning existed in 2.7 as well, but in 2.7 Mask modifiers work perfectly fine when sculpting a shape key, so I find this warning odd in any case.
Related Objects
Mentioned Here
rBa1ae04d15a9f: Versioning: add renaming utility function
T60389: Object preview differences in Sculpt Mode
Demeter Dzadik (Mets) created this task.Feb 2 2019, 12:24 AM
Sebastian Parborg (zeddb) assigned this task to Sergey Sharybin (sergey).Feb 4 2019, 11:37 AM
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
I'm guessing this is related to T60389 (but as that is more of an collection of bugs, I'm unsure if I should merge this in or not).
Demeter Dzadik (Mets) updated the task description.Mar 29 2019, 5:24 PM
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.May 29 2019, 3:00 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Confirmed in rBa1ae04d15a9f: Versioning: add renaming utility function, but appears to be fixed now.
