Maniphest T61261
can't select remaining vertices after hiding a portion
Closed, Duplicate
None
ward (gentleclockdivider)
Feb 6 2019, 10:53 PM
  • BF Blender
Sebastian Parborg (zeddb)
win 10
intel i5
amd radion
blender 2.8
8996e26116f0
Select top four vertices of the cube , press H (hide ) ,
I can't select the remaining vertices when in solid mode ( only in wireframe mode )
Related Objects
Mentioned Here
T60710: subdivision modifier ,adjust edit cage to modifier result , vertex selection bug
rB8996e26116f0: Fix T61196: Mesh select ignores clipping
ward (gentleclockdivider) created this task.Feb 6 2019, 10:53 PM
Campbell Barton (campbellbarton) added a subscriber: Campbell Barton (campbellbarton).Feb 7 2019, 12:07 AM
Can't redo this error.
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
This is probably a duplicate of T60710 as you already have problems selecting things.
The root cause if most likely the same.
