Maniphest T61404
Blender 2.8 beta 32 bits crashes or doesnt start
Closed, Duplicate
None
ben benjamin (benjamin63)
Feb 11 2019, 9:51 AM
None
Jacques Lucke (JacquesLucke)
Hi,
Please notice I am using an old wacom serial tablet with a serial to usb driver ; Intuos GD-0912-R + prolific PL2303 (used driver PL2303_Prolific_DriverInstaller_v1_11_0) + win 8.1
Until now it all works perfectly on 32bit apps.
Operating system: Windows 8.1
Graphics card: Nvidia GeForce GT 520
CPU: Intel(R) Core(TM) i5-2500 CPU @ 3.30Ghz
RAM: 16 GB
Not working: blender-2.80.0-git.69b2f5268114-windows32 (11-02-2019)
Works: 2.79b and the 2.80 beta 64 bits
Blender 2.8 32 bits closes at start-up if no arguments, or when using Grease Pencil or opening files.
Related Objects
Mentioned Here
rB69b2f5268114: DNA: remove Object.display struct
ben benjamin (benjamin63) created this task.Feb 11 2019, 9:51 AM
ben benjamin (benjamin63) added a comment.Feb 11 2019, 9:54 AM
blender.exe --debug --debug-gpu > report.txt
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STREAM_DRAW) will
use VIDEO memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 1 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_DYNAMIC_DRAW) has
been mapped WRITE_ONLY in SYSTEM HEAP memory (fast).
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (0), GL_VERTEX
_ATTRIB_ARRAY_BUFFER_BINDING_ARB (1), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (2), and GL_ARRAY_BUFFER_ARB, usage hi
nt is GL_STREAM_DRAW) will use VIDEO memory as the source for buffer object operations.
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x0170B6DA
Module : C:\Users\mikeo\Desktop\blender-2.80.0-git.69b2f5268114-windows32\blender.exe
ben benjamin (benjamin63) updated the task description.Feb 11 2019, 9:55 AM
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).Feb 11 2019, 11:25 AM
Not sure what is happening. Is there any specific reason why you are using the 32 bit version?
ben benjamin (benjamin63) added a comment.EditedFeb 11 2019, 12:31 PM
Yes the pressure sensitivity of my old serial tablet is working only on 32bits apps :/
It seams to me something is going "too fast" ; if I start directly from the blender icon/exe, it crashes most of the time, and if it sometimes starts, it crashes as soon as I click "General > new file".
Though if I start with the command prompt, particularly with the debug commands, it crashes much less! but gets way too slow, and still crashes easily, e.g. when opening a file, creating an new file, start grease pencil... but not on every time!
Brecht Van Lommel (brecht) closed this task as a duplicate of T60089: 2.80 32-bit appears broken (on 64-bit Windows at least).Feb 11 2019, 1:57 PM
