Maniphest T61410
Driver-controlled renderability unpredictable, and no drivers avail. on viewport visibility
Closed, Duplicate
None
Stephen Hamacek (hammers)
Feb 11 2019, 12:24 PM
  • BF Blender
Philipp Oeser (lichtwerk)
Operating system: Mac OSX 10.13.6
Graphics card: NVIDIA GeForce GTX TITAN X 12288 MB
2.80, 46ac288a9306, blender2.8, 2019-02-08 04:22
Worked: 2.79
  1. Dependency not updating reliably with driver affecting Renderability, and Renders not always honouring current state of Renderability under driver affect.
  1. Also viewport visibility no longer able to add driver to control at all. I have been doing both of these in 2.79 and before quite regularly
Attached simple .blend. Small block z location drives Renderability with z=0 -> renderable, z=1 restricted. Notice lack of reliable correlation. Works if you hit update dependencies in driver editor after each move, but even then actual renders don't always honour current Renderability state.
And yes I have a regular use-case for driving viewport visibility alongside renderability, to control 'parts replacement' style rigs. I hope this feature can be fixed/reinstated soon. Thanks!
Related Objects
Mentioned Here
T56635: Driver/Keyframes on object visibility do not update viewport
rB46ac288a9306: Cleanup: rename V3D_MANIP_* -> V3D_ORIENT_*
Stephen Hamacek (hammers) created this task.Feb 11 2019, 12:24 PM
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Feb 11 2019, 1:50 PM
Duplicate of T56635
Philipp Oeser (lichtwerk) closed this task as a duplicate of T56635: Driver/Keyframes on object visibility do not update viewport.Feb 11 2019, 1:50 PM
