Maniphest T61709
Blender 2.79b bevel messes up texture UV coordinates.
Closed, Duplicate
Howard Trickey (howardt)
Cyp (cyp)
Feb 19 2019, 11:53 AM
  • BF Blender
Cyp (cyp)
Sebastian Parborg (zeddb)
Broken: 2.79b
When bevelling something with texture coordinates, it usually looks really weird.
See attached.
Top left: unbevelled
Top right: 2-segment bevel modifier
Bottom left: 4-segment bevel modifier
Bottom right: What it should have looked like — 4-segment bevel modifier applied and then manually fixed up
Sometimes coordinates can be fixed by scaling them by a factor of 3 with the cursor set to the coordinates of another face.
Screenshot:
Test case:
Cyp (cyp) created this task.Feb 19 2019, 11:53 AM
Sebastian Parborg (zeddb) assigned this task to Howard Trickey (howardt).Feb 19 2019, 6:47 PM
Sebastian Parborg (zeddb) added subscribers: Howard Trickey (howardt), Sebastian Parborg (zeddb).
This also happens in 2.8
@Howard Trickey (howardt) Known limitation or not?
Brecht Van Lommel (brecht) closed this task as a duplicate of T56625: Bevel modifier UV problem with corners.Feb 20 2019, 2:00 PM
Howard Trickey (howardt) mentioned this in T56625: Bevel modifier UV problem with corners.Feb 20 2019, 3:33 PM
