Operating system: Windows 10 x64
Graphics card: RTX 2070
Broken: 2.79, 2.8
When skinned meshes are exported with FBX 7.4 binary the position of vertices does not export correctly.
As a result meshes are deformed (visible but not extreme in most cases) after export.
Note that external tools/software may be required to compare the meshes as the bug may be invisible upon re-import to blender.
A good way to see the differences is to use the mesh wireframe in iso view in blender versus unity for example.
Comparison of before and after in sample case (Click to load gif)
- Load the attached blend file.
- Export to FBX using 7.4 binary
- Compare the position of vertices before and after export.
