Maniphest T61986
Removing fcurves with python code does not work
Closed, Duplicate
None
David Gayerie (Spoonless)
Feb 26 2019, 6:54 PM
  • BF Blender: 2.8
Operating system: Linux
Graphics card: GTX 1060
Broken: 2.80, 54ffc4e19dc4, 2019-02-25
In Python script, when I try to remove fcurve using bpy.types.ActionFCurves.remove
  • the graph editor is correctly updated
  • but the 3D scene is not updated and the animation is still there
  • Open the attached file
  • In the 3D View, start the animation to see the bone moving
  • Run the script to remove all fcurves for the bone
Then the graph editor is updated (animation is removed) but the bone is still animated!
Related Objects
Mentioned Here
rB54ffc4e19dc4: Grease Pencil naming: Use clear names for depth ordering
David Gayerie (Spoonless) created this task.Feb 26 2019, 6:54 PM
David Gayerie (Spoonless) updated the task description.
Sebastian Parborg (zeddb) closed this task as a duplicate of T60086: Removing fcurves/animated transform channels does not work.Feb 26 2019, 7:03 PM
