Maniphest T62218
2.8 | Empty Images have washed out colors in viewport render
Closed, ResolvedKNOWN ISSUE
Clément Foucault (fclem)
Karlo (kpavicic)
Mar 5 2019, 2:45 PM
  • BF Blender
  • EEVEE & Viewport
Brecht Van Lommel (brecht)
Karlo (kpavicic)
William Reynish (billreynish)
Tokens
"Like" token, awarded by gabrielmoro.
Operating system: win7 64
Graphics card: gtx 1080ti
Broken: blender-2.80.0-git.1df6a98b176f-windows64 2019/03/05
Worked: Tried a few random versions, might have never worked in 2.8
Empty Images have washed out colors when rendered using Viewport Render. As far as I see it doesn't affect materials.
Drag and drop any image into the viewport. Go to view> Viewport Render
Related Objects
Mentioned In
T68926: Color Management Improvements
Mentioned Here
rB1df6a98b176f: Cleanup: minor adjustment to gizmo extrude setup
Karlo (kpavicic) created this task.Mar 5 2019, 2:45 PM
Karlo (kpavicic) updated the task description.
William Reynish (billreynish) lowered the priority of this task from 90 to 30.Mar 5 2019, 4:06 PM
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).
Can you please provide a demo blend file that shows this? Thanks.
Karlo (kpavicic) added a comment.Mar 5 2019, 4:54 PM
Blend:
Image showcasing the problem in the attached blend file:
William Reynish (billreynish) added a subscriber: Brecht Van Lommel (brecht).Mar 5 2019, 5:34 PM
In the viewport, reference images aren't affected by color management, but in the rendered output they are.
@Brecht Van Lommel (brecht) It's unclear to me what is the correct or expected behaviour here. In the end this doesn't seem like it's super critical, as reference images are meant for references, not output.
William Reynish (billreynish) raised the priority of this task from 30 to 90.Mar 5 2019, 5:34 PM
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to Low.Mar 5 2019, 6:08 PM
I think there's perhaps a double color transform going on. It won't always match exactly due to use color management settings, but should be closer than this.
Sam Van Hulle (sam_vh) mentioned this in T68926: Color Management Improvements.Sep 5 2019, 12:48 PM
Dalai Felinto (dfelinto) added a project: Tracker Curfew.Dec 23 2019, 4:35 PM
Richard Antalik (ISS) removed a project: Tracker Curfew.Jan 24 2020, 7:57 PM
Richard Antalik (ISS) changed the subtype of this task from "Report" to "Known Issue".
Richard Antalik (ISS) added a project: EEVEE & Viewport.
Gabriel Moro (gabrielmoro) awarded a token.Feb 18 2020, 1:57 AM
Clément Foucault (fclem) closed this task as Resolved.Jun 22 2020, 4:05 PM
Clément Foucault (fclem) claimed this task.
Clément Foucault (fclem) added a subscriber: Clément Foucault (fclem).
This was fixed by the color management refactor in 2.83. The colors do not match 100% (because of different pipeline) but they are not washed out anymore.
