Maniphest T62466
Driver from world custom prop to material not refreshing realtime
Closed, Resolved
None
Vyacheslav (hitrpr)
Mar 11 2019, 7:41 PM
  • BF Blender
  • Tracker Curfew
Joshua Leung (aligorith)
Richard Antalik (ISS)
Vyacheslav (hitrpr)
Operating system: win7 x64
Broken: 2.80 (sub 47), 6fd11a21f5c5, 2019-03-10 22:28
If you will try to connect world`s shader to it`s custom property it is not updates realtime or even do not see the property at all.
Task was closed and moved in ToDo, then abandoned T22698 in 2010.
Still bugged.
file with example:
How it looks:
Related Objects
Mentioned Here
rBf6cb5f54494e: Version bump to 2.80 final release
T22698: Driver using world custom property don't refresh well
rB6fd11a21f5c5: Fix T62255: Blender defaults to "OpenAL Soft" in sound settings, regardless of…
Vyacheslav (hitrpr) created this task.Mar 11 2019, 7:41 PM
Vyacheslav (hitrpr) added a comment.Mar 12 2019, 10:55 AM
The same problem if I want to drive property by bpy.context.scene.render.engine
It is strange that info-editor recieves almost all events (changing render engine or colors) but drivers can`t…
Sebastian Parborg (zeddb) assigned this task to Joshua Leung (aligorith).Mar 13 2019, 1:21 PM
Dalai Felinto (dfelinto) removed Joshua Leung (aligorith) as the assignee of this task.Dec 23 2019, 4:34 PM
Dalai Felinto (dfelinto) added a project: Tracker Curfew.
Dalai Felinto (dfelinto) added a subscriber: Joshua Leung (aligorith).
Richard Antalik (ISS) changed the task status from Confirmed to Needs Information from User.Jan 28 2020, 1:47 PM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
I have re-triaged this report and can not reproduce it.
Can you please check if this is still an issue in latest build?
https://builder.blender.org/download/
Vyacheslav (hitrpr) added a comment.Jan 28 2020, 3:49 PM
@IIS yes, it works now, even in older 2.82 build.
I remember few similar bugs was reported (value stuck, no value transfer).
As I can remember (and it can be wrong): bug was related with depsgraph`s issues.
So theese bugs can be resolved too.
Vyacheslav (hitrpr) added a comment.Jan 28 2020, 3:54 PM
Also works with 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: f6cb5f54494e
So it resolved long time ago.
Vyacheslav (hitrpr) closed this task as Resolved.Jan 28 2020, 4:40 PM
