Maniphest T62677
Blender 2.8. REPEAT LAST action doesn't work properly for editing mode [FOR EXTRUSION]
Closed, Duplicate
None
Ruslan (rs2128)
Mar 17 2019, 12:08 PM
  • BF Blender
  • Tracker Curfew
Ruslan (rs2128)
William Reynish (billreynish)
win 10 - 64 bit
NVIDIA GeForce GTX 560 [last driver version]
Broken: 2.80, dbfbd6b9043d, 2019-03-16
Worked: 2.79b, f4dc9f9d68b, 2018-03-22
Looks like REPEAT LAST action doesn't work properly for editing mode. In particular for extrude operation. When you repeat last extion for extrude - it will allways moves towerd first one extrusion oriented movemant and never toward 'normals'. Even if you will choose any others combinations of transform orientation and pivot point Here is I captured video: https://mega.nz/#!sXYlAIzY!OXinB6ZXQ1FSktu0UkLnnOSDKf_5efb6Pt0EEjAM68Q
Open default file. Put a cube. Turn on edit mode. Select any side and extrude it. Then press SHiFT+R[or open Edit>Repeat last/ or Edit>Repeat History and choose last action] - and repeat action - all looks good. Then take any other side of the cube and press SHIFT+R and you will see that extrusion will oriented toward first one extrusion movement. Even if you will choose any other of transform orientation, you will never get correct result. It's works fine in old version of Blender.
Related Objects
Mentioned Here
rBf4dc9f9d68bd: Fix T54360: FFMPEG bitrate not editable for all codecs
rBdbfbd6b9043d: Fix T62555 Viewport borders flicker when splitting said viewport
Ruslan (rs2128) created this task.Mar 17 2019, 12:08 PM
William Reynish (billreynish) lowered the priority of this task from 90 to 50.Mar 17 2019, 12:17 PM
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).
Yes, I guess Repeat Last should not repeat the last operator using the resulting orientation, but the re-calculate the orientation again.
it might be a hairy issue to solve though.
Dalai Felinto (dfelinto) added a project: Tracker Curfew.Dec 23 2019, 4:34 PM
Richard Antalik (ISS) closed this task as a duplicate of T60069: repeated extrusion is buggy .Jan 28 2020, 4:03 PM
