Maniphest T62739
Bevel Weight not affecting Bevel modifier correctly
Closed, Archived
Howard Trickey (howardt)
Frederico Martins (frederico4d)
Mar 19 2019, 9:58 AM
  • BF Blender
  • Modifiers
William Reynish (billreynish)
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 418.81
Broken: version: 2.80 (sub 50), branch: master, commit date: 2019-03-18 21:39, hash: rBd47f827019f2
Also broken in other versions a couple of days older at least.
Also broken on 2.79 in builder.blender.org (version: 2.79 (sub 7), branch: blender2.7, commit date: 2019-03-14 17:29, hash: 57b5852bc8b8)
Worked: works well on 2.79 stable (version: 2.79 (sub 0), branch: master, commit date: 2018-03-22 14:10, hash: f4dc9f9d68b)
Bevel weight not decreasing bevel smoothly as value decreases when two consecutive edges are being beveled.
Create a look with 2 consecutive edges being affectd by bevel weight, one as a value of 1 and the other change the value with the slider.
if you do that with a bevel modifier, the bevel effect on the mesh will not change smoothly on the geometry.
If you do the same on 2.79 it works very well and smoothly.
I attached a video with a sample of the same function, how it works in 2.79 and in 2.8.
This works almost similarly with percentage method and works well, but I really need it to work with a specific value instead of a percentage, on a specific project.
Related Objects
Mentioned In
T48583: Bevel Improvements
Mentioned Here
rBf4dc9f9d68bd: Fix T54360: FFMPEG bitrate not editable for all codecs
rB57b5852bc8b8: Fix T62120: number button editing outside of soft max range jumps.
Frederico Martins (frederico4d) created this task.Mar 19 2019, 9:58 AM
Frederico Martins (frederico4d) added a project: Modifiers.Mar 19 2019, 10:36 AM
William Reynish (billreynish) assigned this task to Howard Trickey (howardt).Mar 19 2019, 10:55 AM
William Reynish (billreynish) lowered the priority of this task from 90 to 50.Mar 19 2019, 11:02 AM
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).
I can reproduce the difference in behavior here.
@Howard Trickey (howardt) I guess you can confirm if this is intended or not.
Howard Trickey (howardt) added a comment.Mar 19 2019, 11:58 AM
The behavior in 2.79 is not really intended -- it is more an accidental consequence of a choice made to solve conflicting specifications.
What the specifications say is that one edge is supposed to have one particular bevel width all the way along it, and the other edge (with the adjusting weight) is supposed to have another weight all the way along it. Where they meet is a conflict. The conflict used to be solved by taking an average, which gave the smooth tapering effect you saw. But for other cases (especially when there are loops) that is not nearly good enough, so I switched to using a least-squares optimization some time in the 2.79 series (I see that you note that this was working for a while in 2.79 and then stopped working, so maybe that was when I made this switch).
I will see if there is something wrong with the least-squares optimization that can be fixed that would bring the behavior back to what you hoped for.
Howard Trickey (howardt) changed the task status from Unknown Status to Archived.Mar 19 2019, 12:47 PM
Sorry, I am closing this as "working as intended" because the code is doing what I intended: that is, it is choosing to keep widths even along their edges as a higher priority than trying to half-way meet an unmeetable set of width constraints.
Others have asked for some kind of "taper" support, though usually on just one edge. I will add that idea to my list of feature requests, T48583.
Howard Trickey (howardt) mentioned this in T48583: Bevel Improvements.Mar 19 2019, 12:48 PM
Frederico Martins (frederico4d) added a comment.Mar 19 2019, 2:25 PM
Thank you,
that is sad for me unfortunately since there is no other way to do this in blender without just working on geometry and loosing editability :( this was a great feature for me, on this project and other stuff ive used it before (RIP).
I will keep using 2.79 on this project since this something vital for it, but I already miss the great new tools i've been using in 2.8.
