Maniphest T62812
Circle Cursor not selection
Closed, Archived
William Reynish (billreynish)
Ron Lasser (rlece)
Mar 21 2019, 11:31 AM
  • BF Blender
Ankit Meel (ankitm)
Eugene Du (APEC)
Ron Lasser (rlece)
Operating system: MacBook Pro, Mojave 10.14.3
Graphics card: Intel Iris Plus Graphics 655
Broken: Version 2.80 (2.80 2019-03-18, Blender Foundation) - found in object view
Circle cursor - with only camera, lamp and cube in object mode, user perspective, the circle cursor will select three items properly. When they are deselected and then one of them is selected again with the circle cursor, the cursor does not select them as they do not turn orange.
Startup Blender.
Click to dismiss splash screen.
Select circle cursor from "T" menu.
Select camera, lamp, and cube one at a time holding shift key.
Click mouse anywhere else to deselect all.
Select camera or lamp or cube -- without holding shift key -- none of the items are selected, that is, turn orange.
This can be repeated on four attempts producing the same results
Ron Lasser (rlece) created this task.Mar 21 2019, 11:31 AM
William Reynish (billreynish) lowered the priority of this task from 90 to 30.Mar 21 2019, 11:37 AM
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).
Cannot reproduce.
Unless you mean that the cube stays active? If so, that is how Blender works and has always worked. An object can be either selected or active, which are two different things.
Ron Lasser (rlece) added a comment.Mar 21 2019, 12:01 PM
When selecting with the Select cursor, the cursor can be on any part of the object -- camera, cube, or lamp in the starting scene, and the object is selected, highlighted in orange.
When using the Circle cursor, the cursor must be on the center of the object to select it to be highlighted. If it is any other part of the object, the object is not selected.
See attached images.
If this is the correct operation, then please cancel the bug report.
William Reynish (billreynish) changed the task status from Unknown Status to Archived.Mar 21 2019, 1:01 PM
William Reynish (billreynish) claimed this task.
William Reynish (billreynish) added a subscriber: Campbell Barton (campbellbarton).
This is how Circle Select worked in previous versions of Blender too, so it doesn't appear to be a bug. I'm not sure why.
@Campbell Barton (campbellbarton): Is there a reason why circle select only works on origins in Object Mode?
Campbell Barton (campbellbarton) added a comment.Mar 21 2019, 1:17 PM
@William Reynish (billreynish) I wasn't involved in this particular decision, however this can be useful (eg, selecting face centers in wire-mode is handy).
It's useful for lasso select since you can drag quick/sloppy selections and not worry a stray wire line poking out of an object causes it to be included in the selection.
William Reynish (billreynish) added a comment.Mar 21 2019, 1:19 PM
@Campbell Barton (campbellbarton) Yes, it just seems a bit inconsistent, given that Box Select doesn't work this way. Down the road, we could add a tool setting for it I suppose. But it's not a high priority item IMO.
Ankit Meel (ankitm) added a subscriber: Eugene Du (APEC).
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).
Eugene Du (APEC) added a comment.EditedMay 3 2020, 12:13 PM
So all tasks closed, and no solution even for Lasso Selection in Object Mode?
You have 2 modes for Lasso in Edit mode (wire-mode and regular) where lasso select only centers in wire and select all faces in area for regular mode...
Why not implement for Lasso selection Box-like selection in Object mode?
