Maniphest T62897
Shading Workspace issue on Mac platform 10.11.06
Closed, Duplicate
None
Doug Brown (dougieladd)
Mar 24 2019, 3:16 PM
  • BF Blender
Brecht Van Lommel (brecht)
Jacques Lucke (JacquesLucke)
Operating system: OS X El Capitan Version 10.11.6
Graphics card:NVIDIA GeForce 9400 256MB
Memory: 8gig RAM
Broken: Version 2.80 (2.80 2019-03-24, Blender Foundation)
The display of the Shading workspace is glitchy... the two globes in LookDev mode show as solid black and when rotating the viewport they have a solid white "shadow". Adding a material has no effect. Adding a new material has no effect when changing Base colour in the Principled shader for example. This is also true of all modes... Solid, LookDev and Rendered. Material shading has no effect. And the white "shadows" break up and disappear when rotating the view.
I have a feeling it just may be a limitation of my Mac hardware. But I just want to be sure since I have downloaded multiple builds and they all display this way.
Doug Brown (dougieladd) created this task.Mar 24 2019, 3:16 PM
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 30.Mar 25 2019, 1:39 PM
Jacques Lucke (JacquesLucke) added a subscriber: Jacques Lucke (JacquesLucke).
Please check if your GPU driver is up to date.
Furthermore, it would be helpful if you make a short screen recording that shows the problem.
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).EditedMar 25 2019, 3:11 PM
On macOS it's not possible to upgrade graphics drivers on their own, only upgrading the operating system as a whole. We've had some reports before about NVIDIA GPUs and macOS 10.11, which do not happen in newer macOS versions. We might drop support for 10.11 and lower due to too buggy drivers, it has not been decided yet.
T60179 might be the same issue. It can help to try to narrow down the issue, like disabling Eevee features, removing lights, disabling shadows, ... to see what exactly causes the problem.
Doug Brown (dougieladd) added a comment.Mar 25 2019, 9:04 PM
Thanks Brecht -
I will definitely update my OS as soon as possible. In the meantime I've attached a screen share video showing the issue. (hopefully its not me just being stupid :)
Thanks again,
D
Brecht Van Lommel (brecht) added a comment.Mar 28 2019, 8:28 PM
Looks like the same issue with the white cube.
Brecht Van Lommel (brecht) closed this task as a duplicate of T60179: Bad render of default scene Mac OSX.Mar 28 2019, 8:28 PM
