Maniphest T63019
can't lasso select multiple vertices when see trough it enabled and my active tool is the move tool
Closed, Duplicate
None
ward (gentleclockdivider)
Mar 27 2019, 4:47 PM
  • BF Blender
win 10
intel i5
amd radeon
blender 2.8
337eb8c1de4c
When see trough is enabled , I can't lasso select multiple vertices .
My active tool is the move tool , so ctrl select +left mouse is my lasso tool .
I am still using right mouse select
This didnt t happen with the previous beta
Related Objects
Mentioned Here
rB337eb8c1de4c: Python API: add more detailed example for RenderEngine.
ward (gentleclockdivider) created this task.Mar 27 2019, 4:47 PM
ward (gentleclockdivider) added a comment.EditedMar 27 2019, 4:58 PM
Can't even select edges with ctrl + left click ( again move tool is focused ) , so ctrl . left click = lasso
But this time also in wireframe mode without see trough
When using the lasso tool as primary tool , everything works
The picture shows what's currently not possible in the latest beta
ward (gentleclockdivider) added a comment.EditedMar 27 2019, 5:26 PM
Some more info
So it seems that the selection only shows up after I have shift right clicked the object
Picture 1 shows a sphere where I have lasso selected a star shaped region in the middle of the sphere , it clearly shows nothing .
As usual , the move tool is my prinary tool , the lasso selection is ctrl+left click
Picture 2 shows the selection after shift +richt clicking , or ctrl + right clicking
Then the selection shows up
For the edges it's the same issue , with the exception that the selection also doesn't show up in regular wireframe ( without see trough )
It all behaves correctly when lasso select is the primary tool , it only happens when move is primary and lasso = ctrl + left click
