Maniphest T63047
Camera with negative scale works only in Cycles Rendered view
Closed, ResolvedKNOWN ISSUE
Clément Foucault (fclem)
Maciej Niezgódka (senteria)
Mar 28 2019, 1:34 PM
  • BF Blender
  • EEVEE & Viewport
Philipp Oeser (lichtwerk)
Sebastian Parborg (zeddb)
Operating system: Windows-10-10.0.15063 64 Bits
Graphics card: Quadro K2200/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.78
Broken: version: 2.80 (sub 51), branch: blender2.7, commit date: 2019-03-28 00:40, hash: rBcd92f8ea4626
For composition of render very important is to keep balance between object distribution in scene. To be sure that my composition is right I always check my view mirroring camera (Ctrl+M -> double x). Unfortunately this works OK only in rendering view. Can you fix this, that I'll use it in Solid view too?
1 - Standard Solid camera view
2 - Mirrored Solid camera view
3 - Standard Rendered camera view
4 - Mirrored Rendered camera view
Revisions and Commits
rB Blender
Maciej Niezgódka (senteria) created this task.Mar 28 2019, 1:34 PM
Sebastian Parborg (zeddb) renamed this task from Mirror camera works only in Rendered view to Camera with negative scale works only in Cycles Rendered view.Mar 28 2019, 2:08 PM
Sebastian Parborg (zeddb) assigned this task to Clément Foucault (fclem).
Sebastian Parborg (zeddb) added subscribers: Clément Foucault (fclem), Sebastian Parborg (zeddb).
@Clément Foucault (fclem) is this something we could easily support? Known limitation or not?
Clément Foucault (fclem) lowered the priority of this task from 50 to Low.Mar 28 2019, 6:03 PM
This is more of a feature request than a bug report. Putting on low priority.
Maciej Niezgódka (senteria) added a comment.Mar 28 2019, 6:30 PM
Sorry, but I don't agree with you, because this is how it works correct in Blender 2.7x, so in my opinion this is a bug. This tool is used usually in my workflow.
Clément Foucault (fclem) raised the priority of this task from Low to Normal.Mar 29 2019, 3:52 PM
Ok will try to fix it. Do note that it was also buggy in 2.7 since backface culling was inverted.
Maciej Niezgódka (senteria) added a comment.Mar 29 2019, 4:05 PM
OK, Sorry, but I didn't know it, because I stopped with Blender 2.77 with Vray additions, and now doing all stuff well with great 2.8. Thank you for changing priority :)
Philipp Oeser (lichtwerk) added projects: GPU / Viewport, Eevee.Nov 20 2019, 10:37 AM
Maciej Niezgódka (senteria) added a comment.Nov 21 2019, 8:48 AM
Hello, I know, that all of developers are very busy, but I would like to ask - any news about fixing it? For me it is very important to check my scene composition with mirrored viewport shot.
Dalai Felinto (dfelinto) removed Clément Foucault (fclem) as the assignee of this task.Dec 23 2019, 4:34 PM
Dalai Felinto (dfelinto) added a project: Tracker Curfew.
Jeroen Bakker (jbakker) removed projects: Tracker Curfew, Eevee.Jan 10 2020, 1:43 PM
Jeroen Bakker (jbakker) changed the subtype of this task from "Report" to "Known Issue".
Clément Foucault (fclem) closed this task as Resolved by committing rBf972a3c31458: DRW: Support inverted view matrix.Feb 19 2020, 7:37 PM
Clément Foucault (fclem) claimed this task.
Clément Foucault (fclem) added a commit: rBf972a3c31458: DRW: Support inverted view matrix.
Clément Foucault (fclem) edited projects, added EEVEE & Viewport; removed GPU / Viewport.Jun 19 2020, 11:07 PM
