Maniphest T63116
2.8 blender freezes during preview render when using adaptive subdivision/displacement node with low displacement scale values
Closed, Duplicate
None
Jim C (semaj)
Mar 30 2019, 2:07 AM
  • BF Blender
Jim C (semaj)
Graphics card: Quadro 1000M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 354.42
Broken: version: 2.80 (sub 52), branch: master, commit date: 2019-03-29 00:43, hash: rB99d4321feff6
Worked: 2.79
Blender freezes when trying to initiate preview render while using adaptive subdivision/displacement node in experimental feature set with either small displacement scale or small dicing scale.
  1. see attached blend file and use small displacement scale values or small dicing scale values.
http://pasteall.org/blend/index.php?id=51468
For example:
Preview render does initiate with displacement node scale value at .2 and dicing value at 1.00, but freezes if displacement scale value is set to .1. Blender will not freeze if displacement node is set to .1 and dicing value is at 3.00, for example, but will freeze if dicing value is set to 2.00.
Jim C (semaj) created this task.Mar 30 2019, 2:07 AM
Jim C (semaj) renamed this task from 2.8 adaptive subdivision/displacement node freezes when displacement scale is set to low values to 2.8 adaptive subdivision/displacement node freezes before preview render when displacement scale is set to low values.Mar 30 2019, 2:14 AM
Jim C (semaj) renamed this task from 2.8 adaptive subdivision/displacement node freezes before preview render when displacement scale is set to low values to 2.8 blender freezes during preview render when using adaptive subdivision/displacement node with low displacement scale values .
Jim C (semaj) updated the task description.
Jim C (semaj) updated the task description.Mar 30 2019, 4:56 AM
