Operating system: Windows 10
Graphics card: GTX1080Ti
Broken: 2.8 latest master
Worked: probably never
Currently, it is not possible to hotkey activation of the select tool in the toolbar. It is only possible to directly hotkey select tools mode, using operators such as builtin.select_box, builtin.select_lasso, builtin.select_circle etc... but this means that user can not create a hotkey which would bring him in the select tool in the last mode he has set up. This means that user has to manually change select mode of the select tool every time he switches back to the tool. There is no hotkey-able equivalent of just clicking on the select tool in the toolbar.
1, Assign a shortcut to select tool on the toolbar
2, Change select tool to different mode (for example circle)
3, Switch to different tool
4, Switch back to select tool using the assigned shortcut
Result: The select tool mode was reverted to the one selected when the shortcut was assigned through the UI context menu
Expected: The select tool remains in last manually selected mode when activated through the assigned shortcut, in the same way when it's clicked on using a mouse cursor.
