Maniphest T63419
Add Select to Drag Action menu
Closed, ArchivedTO DO
William Reynish (billreynish)
Apr 9 2019, 3:19 PM
  • Code Quest
  • User Interface
  • BF Blender: 2.8
Alexander Dumproff (A.Lex_3D)
Craig Jones (craig_jones)
Dan Pool (dpdp)
DIGVIJAY (DJAY)
Duarte Farrajota Ramos (duarteframos)
Gibran Kaleel (razgriz286)
Ludvik Koutny (rawalanche)
3 More Subscribers
Tokens
"Like" token, awarded by xrg."Love" token, awarded by jonathanl.
With any tool that uses a gizmo, it can be useful to make the Drag Action be customisable, so that you can still drag inside the viewport to box select. Many users have requested this, so adding it here.
This can only work for certain tools that include gizmos, otherwise they just cannot work.
Related Objects
StatusSubtypeAssignedTask
ConfirmedDESIGNCampbell Barton (campbellbarton)
ConfirmedTO DOCampbell Barton (campbellbarton)
ArchivedTO DOCampbell Barton (campbellbarton)
William Reynish (billreynish) lowered the priority of this task from 90 to Normal.Apr 9 2019, 3:19 PM
William Reynish (billreynish) created this task.
William Reynish (billreynish) mentioned this in T56571: Tools: Per-tool Todo List .Apr 9 2019, 3:28 PM
Ludvik Koutny (rawalanche) added a comment.EditedApr 9 2019, 3:33 PM
I think it could be a good idea if there was just one "Select" entry which would respect whatever mode the select tool is set to inside the toolbar. Otherwise switching between select tool modes would then also require user to switch to that different select tool mode in each of the 4 transform tools. That could result in overwhelming micromanagement of selection behavior across every other tool in the toolbar. Or the drag action should be a global setting for all the tools, not remembered per tool.
Jonathan Lampel (jonathanl) awarded a token.Apr 9 2019, 6:11 PM
xrg (xrg) awarded a token.Apr 9 2019, 6:26 PM
Dan Pool (dpdp) added a comment.Apr 9 2019, 10:49 PM
Agreed. This should be unified across operators and the option tweak added where applicable.
William Reynish (billreynish) changed the task status from Unknown Status to Unknown Status.Apr 13 2019, 12:35 PM
This is now solved differently by being able to make Transform gizmos persistent so you can use them with the selection tools.
