Maniphest T63445
Object with drivers and hooks changes scale when switching to rendered view
Closed, Resolved
Sebastian Parborg (zeddb)
Armando Tello (ckat609)
Apr 10 2019, 4:49 AM
  • BF Blender
Philipp Oeser (lichtwerk)
Operating system: Windows 10 Pro
Graphics card: Nvidia 2x1080GTX
Broken: 2.80, 009dbc2bc9fb, 2019-04-10
Worked: 2.80, d2d84132ddf9, 2019-04-07
There are two issues going on, both that can't be replicated with a new scene and a cube. I'm not sure what's going on. Both issues are happening within the same file, but I isolated each issue with the least amount of objects in its own blend file because there were hundreds of objects and drivers, so it would be even harder to pinpoint the problem.
First issue (single0x0.blend)
When you switch to rendered view, the "door" object is rendered at a different scale, but the scale values don't actually change.
This issue is not present in older versions of 2.8 (2019-04-07).
  • open single0x0.blend file
  • switch to rendered view
Related Objects
Mentioned In
T63446: Object with drivers and hooks crashes blender when switching to rendered view
Mentioned Here
rBd2d84132ddf9: Merge branch 'blender2.7'
rB009dbc2bc9fb: Fix T63427: Annotations don'twork with 2.79 settings
Armando Tello (ckat609) created this task.Apr 10 2019, 4:49 AM
Armando Tello (ckat609) updated the task description.Apr 10 2019, 4:56 AM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Apr 11 2019, 10:05 AM
Seems I cannot reproduce [door seems to be the same size in Lookdev and Rendered view...]
(also changing e.g. the hingeHeight prop seems to work OK...)
got a bunch of missing libs [but it appears these are only materials and are probably unrelated]
Read blend: /home/philippo/Downloads/Blender Bugtracker/T63445/single0x0.blend
Info: Read library: '/home/philippo/Downloads/Blender Bugtracker/T63445/materials/metalPaintedWhite.blend', 'materials\metalPaintedWhite.blend', parent '<direct>'
Warning: Cannot find lib '/.../T63445/materials/metalPaintedWhite.blend'
Warning: LIB: Material: 'metalPaintedWhite' missing from '/.../T63445/materials/metalPaintedWhite.blend', parent '<direct>'
Info: Read library: '/.../elfa/materials/plasticGrayTranslucentSmooth.blend', '
..\elfa\materials\plasticGrayTranslucentSmooth.blend', parent '<direct>'
Warning: Cannot find lib '/.../elfa/materials/plasticGrayTranslucentSmooth.blend'
Warning: LIB: Material: 'plasticGrayTranslucentSmooth' missing from '/.../elfa/materials/plasticGrayTranslucentSmooth.blend', parent '<direct>'
Info: Read library: '/.../elfa/materials/plasticWhiteTranslucentSmooth.blend', '//..\elfa\materials\plasticWhiteTranslucentSmooth.blend', parent '<direct>'
Warning: Cannot find lib '/.../elfa/materials/plasticWhiteTranslucentSmooth.blend'
Warning: LIB: Material: 'plasticWhiteTranslucentSmooth' missing from '/.../elfa/materials/plasticWhiteTranslucentSmooth.blend', parent '<direct>'
the there is also missing external files [not sure what BackBottomLeft.py does? -- probably unrelated as well...]:
Warning: Path '/Aplicaciones/Addons/Blender Addons/BackBottomLeft.py' not found
Warning: Path '/.../highres/rooms/hdri/canada_montreal_thea_Small.exr' not found
Warning: Path '/.../highres/rooms/textures/concreteFresco.jpg' not found
Warning: Path '/.../highres/rooms/textures/concreteStucco.jpg' not found
Warning: Path '/.../T63445/materials/metalPaintedWhite.blend' not found
Warning: Path '/.../elfa/materials/plasticGrayTranslucentSmooth.blend' not found
Warning: Path '/.../elfa/materials/plasticWhiteTranslucentSmooth.blend' not found
But just to make sure we are all on the same page: could you upload your file again (with everything packed or added to a zip archive)?
Maybe you could also provide a screenshot showing the difference between LookDev and Rendered?
Armando Tello (ckat609) added a comment.Apr 11 2019, 6:37 PM
Again, sorry for all the missing links. Here's the (hopefully) fixed file with no materials and other linked stuff. I also made a video for this issue that hopefully show the issue a bit clearer.
Here's the link to the video
https://youtu.be/cnAydx-Ie0w
Philipp Oeser (lichtwerk) raised the priority of this task from 30 to 90.Apr 24 2019, 11:01 AM
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Apr 25 2019, 4:35 PM
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
I can't reproduce this on my end. Does this still happen for you with the latest blender beta?
Armando Tello (ckat609) added a comment.Apr 25 2019, 6:11 PM
I downloaded last night's build and it seems the problem is gone now... go figure.
Sebastian Parborg (zeddb) changed the task status from Unknown Status to Resolved.Apr 25 2019, 6:30 PM
Sebastian Parborg (zeddb) claimed this task.
