Maniphest T63446
Object with drivers and hooks crashes blender when switching to rendered view
Closed, Resolved
Sebastian Parborg (zeddb)
Armando Tello (ckat609)
Apr 10 2019, 4:54 AM
  • BF Blender
Philipp Oeser (lichtwerk)
Operating system: Windows 10 Pro
Graphics card: Nvidia 2x1080GTX
Broken: 2.80, 009dbc2bc9fb, 2019-04-10
Worked: 2.80, d2d84132ddf9, 2019-04-07
There are two issues going on, both that can't be replicated with a new scene and a cube. I'm not sure what's going on. Both issues are happening within the same file, but I isolated each issue with the least amount of objects in its own blend file because there were hundreds of objects and drivers, so it would be even harder to pinpoint the problem.
Second issue (wall.blend)
When switching to rendered view in the viewport, blender crashes. The console shows a memory error before closing itself.
Error: EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF741AC7203
Module: C:\B28\blender.exe{F6925444}
This issue is not present in older versions of 2.8 (2019-04-07).
  • open wall.blend file
  • switch to rendered view
Related Objects
Mentioned Here
T63445: Object with drivers and hooks changes scale when switching to rendered view
rBd2d84132ddf9: Merge branch 'blender2.7'
rB009dbc2bc9fb: Fix T63427: Annotations don'twork with 2.79 settings
Armando Tello (ckat609) created this task.Apr 10 2019, 4:54 AM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Apr 11 2019, 10:27 AM
Seems I cannot reproduce here [no crash]
I am getting the same missing libs/external files as stated in T63445.
In addition, in this file I get:
[SCScene :: RenderLayer]: BKE_animsys_eval_driver on OBmeshWall (0x7f97f065a608) fcu ["openingWidth"][0] (0x7f97f4e18f88)
ERROR (bke.anim_sys): /blender/source/blender/blenkernel/intern/anim_sys.c:3795 BKE_animsys_eval_driver: invalid driver - ["openingWidth"][0]
[SCScene :: RenderLayer]: BKE_animsys_eval_driver on OBmeshWindowPanesBorder (0x7f97e8fe0008) fcu hide_render[0] (0x7f97f1697a88)
[SCScene :: RenderLayer]: BKE_animsys_eval_driver on OBmeshWall (0x7f97f065a608) fcu ["openingLeft"][0] (0x7f97f4e18008)
ERROR (bke.anim_sys): /blender/blenkernel/intern/anim_sys.c:3795 BKE_animsys_eval_driver: invalid driver - ["openingLeft"][0]
Here, openingLeft and openingWidth custom properties seem to be missing on the meshWall object? If I add these by hand the driver errors go away...
So I suggest to try a couple of things to proceed with this report:
  • could you try "fixing" the two erroring drivers like I did (and see if this will prevent the crash)?
  • if that doesnt work: could you try removing the drivers on visibility (and see if this will prevent the crash)?
  • if that also doesnt crash: could you reupload the .blend with everything packed [just so we are all on the same page and can investigate further...]
Armando Tello (ckat609) added a comment.Apr 11 2019, 6:33 PM
Sorry about all the missing files. Here's the (hopefully) fixed file with no materials.
When I added the missing custom properties, something else came up. When I add the custom properties, they are added with drivers already attached to them. No idea what that is all about - maybe it's just me being stupid. Anyway... I made a video of it that hopefully shows the problem a bit clearer. I'm attaching two files this time.
bug_wall_fixedCustomProperty.blend : file with the custom properties that were missing, already added (btw... these custom properties weren't being used, that's why I got rid of them)
bug_wall_addCustomProperty.blend file without the custom properties added. You can add them yourself to reproduce the issue described in the video.
Here's the link to the video
https://youtu.be/HdpJdfNNIHs
Philipp Oeser (lichtwerk) raised the priority of this task from 30 to 90.Apr 24 2019, 11:00 AM
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Apr 25 2019, 4:40 PM
Sebastian Parborg (zeddb) added a subscriber: Sebastian Parborg (zeddb).
As with the other report, I can't seem to reproduce this either. Is this also still an issue with the latest blender beta?
Armando Tello (ckat609) added a comment.Apr 25 2019, 6:11 PM
I downloaded last night's build and it seems the problem is gone now... go figure.
Sebastian Parborg (zeddb) changed the task status from Unknown Status to Resolved.Apr 25 2019, 6:31 PM
Sebastian Parborg (zeddb) claimed this task.
