Maniphest T63654
Alembic - Aplly scale doesn't work with the Mesh Sequence and hair
Closed, Archived
Sybren A. Stüvel (sybren)
Serj Maiorov (printerkiller)
Apr 16 2019, 10:37 AM
  • BF Blender
  • Alembic
Sebastian Parborg (zeddb)
Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 418.96
Broken: version: 2.80 (sub 57), branch: master, commit date: 2019-04-14 19:18, hash: rB860a9f979d60
I have lots of brushed hair on a character. Scaling is crucial to hair systems, and when I import an Alembic without animation, All I have to do is to scale the alembic to the size of my character, apply scale and copy all the hairs systems - works like magic.
The problem begins when I import an animated alembic, no matter what I do the hair goes craze and when I apply the scale it jumps back to its original size and messes the hair again.
All I need to do is to import the alembic' copy weight paints, copy all the particles systems, scale the Alembic to the right size, apply scale - and it jumps back.
tried to import an Alembic with smaller scaler beforehand but didn't work either
RAR file with Blend and Alembic
Related Objects
Mentioned Here
rBee8aad79c159: Fix T56408: Hair children recalc on every frame on Alembic mesh
T63534: Child hair particles set to "Interpolated" causes jittering when groom on alembic cache
Serj Maiorov (printerkiller) created this task.Apr 16 2019, 10:37 AM
Serj Maiorov (printerkiller) updated the task description.
Serj Maiorov (printerkiller) renamed this task from Alembic - Aplly scale doesn't work with the Mesh Sequence to Alembic - Aplly scale doesn't work with the Mesh Sequence and hair.Apr 16 2019, 10:40 AM
Serj Maiorov (printerkiller) added a project: Alembic.
Sebastian Parborg (zeddb) assigned this task to Sybren A. Stüvel (sybren).Apr 16 2019, 2:00 PM
Sebastian Parborg (zeddb) added subscribers: Sybren A. Stüvel (sybren), Sebastian Parborg (zeddb).
Unsure if applying scale is supported for sequence caches. @Sybren A. Stüvel (sybren) any input on this?
Sybren A. Stüvel (sybren) added a comment.Apr 16 2019, 3:19 PM
Applying scale is not supported. This changes the mesh data, which is replaced with the data from Alembic. Try creating an Empty, set it as the parent of the imported Alembic object, and scale the Empty.
Serj Maiorov (printerkiller) added a comment.Apr 16 2019, 3:47 PM
Tried to do that but it still breaks the hair
Serj Maiorov (printerkiller) added a comment.Apr 17 2019, 9:33 AM
Is there an alternative to that workflow? Because we use real world scales to be consistent with lighting and materials over live footages. How can we interchange hair between Alembics and still maintain real scales?
Sybren A. Stüvel (sybren) lowered the priority of this task from 50 to 30.Aug 1 2019, 4:42 PM
Blender's hair system is very picky when it comes to the mesh it's attached to. Especially when grooming, it is vital that the face & vertex indices remain the same. Are you sure that the mesh in Alembic didn't change between grooming the hair in Blender and getting these errors?
Please provide us with an as-simple-as-possible test file. This file has various hidden (and thus probably irrelevant) objects, three different hair systems, and a subdivision modifier that may or may not influence the result.
As an alternative workflow, what is stopping you from exporting to Alembic in the correct scale, so that later stages in the pipeline can just use the file as-is?
Sybren A. Stüvel (sybren) added a comment.Aug 13 2019, 3:44 PM
This is probably the same issue as T63534.
Sybren A. Stüvel (sybren) changed the task status from Unknown Status to Unknown Status.Aug 16 2019, 2:56 PM
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to archive the report until the requested information is given.
This issue is probably solved in ee8aad79c159. If not, please provide the requested information.
