Maniphest T63801
Blender 2.80 - Intel HD Graphics Glitch: Reference Image "cover" objects instead of appearing under them.
Closed, Resolved
Brecht Van Lommel (brecht)
Francesco Sorrentino (zeirus)
Apr 22 2019, 2:54 PM
  • BF Blender
  • Platform: Windows
Clément Foucault (fclem)
Jeroen Bakker (jbakker)
Mohamed El Hamd (elbox01)
Sebastian Parborg (zeddb)
Graphics card: Intel(R) HD Graphics Intel 4.4.0 - Build 20.19.15.5063
Broken: version: 2.80 (sub 57), branch: blender2.7, commit date: 2019-04-17 19:26, hash: rBb46245470f79
Blender 2.80 - Intel HD Graphics Glitch: Reference Image "cover" objects instead of appearing under them (but only in Windows 10)
In Windows 10 a strange thing happens: The reference image that I use to model is seen "above" the objects, covering them entirely. Instead, with the same PC but in Ubuntu Mate, this doesn't happen. I attach textual debug files and also several screens (from #001 to #004) showing the bug found. Instead the screenshot #005 shows the same file opened in Ubuntu Mate but with build version of Blender 2.80 released on April 22.
Francesco Sorrentino (zeirus) created this task.Apr 22 2019, 2:54 PM
Francesco Sorrentino (zeirus) added a project: Platform: Windows.
Francesco Sorrentino (zeirus) updated the task description.Apr 22 2019, 3:01 PM
Mohamed El Hamd (elbox01) added a subscriber: Mohamed El Hamd (elbox01).Apr 22 2019, 7:23 PM
I can confirm this Bug.
Like @Francesco Sorrentino (zeirus) said, happens only on Windows.
My specs:
  • Operating system: Windows 10 (1809) 64 Bits
  • Graphics card: Intel(R) HD Graphics Intel 5500 (with same driver)
I have watched somewhat related issue T60484 which seems solved the issue for linux, but not for windows.
Mohamed El Hamd (elbox01) added a comment.Apr 22 2019, 7:33 PM
This happens too even when there is an intersection between Reference Image and an object.
Francesco Sorrentino (zeirus) added a comment.Apr 22 2019, 9:38 PM
My specs:
Ok. Thanks to your help I found a trick to terminate the project in Windows without going to Linux: I set "Depth" to "Back" and even if the objects that go under the reference image line do not disappear, at least I can work keeping the image active . However I found another bug: by moving the offset values with the buttons, the value of 0.50 does not change but the image moves anyway. I assume that the thousandths (eg 0.501 - 0.502 etc.) are not displayed.
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.Apr 23 2019, 10:13 AM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Please attach a .blend file to reproduce the problem.
Mohamed El Hamd (elbox01) added a comment.Apr 23 2019, 11:57 AM
@Brecht Van Lommel (brecht).
Sorry to intervene, Even though I am not OP but I have this problem too.
This bug can be reproduced with the default scene:
And I suspect that this bug appears on Intel HD Graphics (only Windows).
Francesco Sorrentino (zeirus) added a comment.Apr 23 2019, 3:06 PM
Hi Brecht,
Please find attached file .blend with screenshot
Here is the driver I used for Windows 10 64 bit
Intel HD Driver
Here the specification of my PC barebone
GB-BACE-3150
Thanks for the attention
Brecht Van Lommel (brecht) raised the priority of this task from 30 to 90.Apr 30 2019, 12:59 PM
Sebastian Parborg (zeddb) added subscribers: Jeroen Bakker (jbakker), Sebastian Parborg (zeddb).Jun 11 2019, 12:58 PM
@Jeroen Bakker (jbakker) can you take a look at this?
Clément Foucault (fclem) added a subscriber: Clément Foucault (fclem).Jul 9 2019, 8:58 PM
Can you update your video drivers from intel's website?
Francesco Sorrentino (zeirus) added a comment.Jul 9 2019, 11:53 PM
Hi Clement.
Hi Clement. I have used the latest drivers on the official Intel site.
Version: 15.40.42.5063
(Latest) Date: 3/19/2019
These specific drivers have not been updated by Intel:
https://downloadcenter.intel.com/download/28662/Intel-Graphics-Driver-for-Windows-15-40-?product=80939
Mohamed El Hamd (elbox01) added a comment.Jul 23 2019, 2:00 PM
Just for letting you know, That this issue doesn't exist anymore on my Windows environment (Windows 10, Intel HD Graphics 5500, driver 20.19.15.5063 date 10/29/2018) which I believe is the same as @Francesco Sorrentino (zeirus) 's graphic card. but I am not talking on behalf of the OP here.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Aug 2 2019, 2:05 PM
Assuming this is fixed then, we can reopen the report if it's not the case.
