Maniphest T63844
ALT+ LMB doesnt work for switching on/of modifiers with multi users
Closed, Archived
William Reynish (billreynish)
Alex (AlexBitsadze)
Apr 24 2019, 1:50 AM
  • BF Blender
Alex (AlexBitsadze)
Philipp Oeser (lichtwerk)
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 417.35
Broken: version: 2.80 (sub 58), branch: master, commit date: 2019-04-23 17:06, hash: rBf32902e6dacf
when i press alt + LMB to temporary turn off/on the modifiers from the view with multi users it doesnt work. here is the screenshot and blendfile
Alex (AlexBitsadze) created this task.Apr 24 2019, 1:50 AM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Apr 24 2019, 9:44 AM
Working fine here.
  • does this fail with Factory Settings as well?
  • which keymap are you using?
William Reynish (billreynish) added a subscriber: William Reynish (billreynish).Apr 25 2019, 2:42 PM
Just guessing, but it could be because you are using Emulate 3 Button Mouse, which makes Alt-click not work (it emulates middle mouse instead).
Really this issue should be solved by properly supporting Multi-Object Properties Editing by default T54987 without requiring holding the Alt-key.
Alex (AlexBitsadze) added a comment.May 4 2019, 4:03 PM
Yes you are right. I turned off the Emulate 3D mouse and it helped but it should be like that? what if I want it to be on and disable modifiers for several users?
Alex (AlexBitsadze) added a comment.May 4 2019, 4:04 PM
In T63844#665056, @Philipp Oeser (lichtwerk) wrote:
Working fine here.
it works fine on factory settings. as William Reynish said it was because emulate 3D mouse function. is it on default or is it bug? cuz maybe I need to have both functions on?
William Reynish (billreynish) added a comment.May 4 2019, 4:04 PM
Then right click and pick Copy to Selected, if you have no Alt key:
William Reynish (billreynish) changed the task status from Unknown Status to Archived.May 4 2019, 4:09 PM
William Reynish (billreynish) claimed this task.
Alex (AlexBitsadze) added a comment.May 4 2019, 5:02 PM
okay, thank you very much!
