Maniphest T64370
Invert slots order in Image Editor to match shortcuts
Closed, Archived
Brecht Van Lommel (brecht)
Guillaume Audirac (gadic)
May 9 2019, 10:59 AM
  • BF Blender
Marco (nacioss)
William Reynish (billreynish)
Drop-down menus support quick shortcuts with numbers ('1' for first menu entry, etc.).
The Slot drop-down menu works today with the shortcuts: '1' for Slot 8, '2' for Slot 7, etc.
It would be more relevant with the order matching the numerical shortcuts: '1'=Slot 1, '2'=Slot 2, etc.
So basically to invert the Slot list.
Related Objects
Guillaume Audirac (gadic) created this task.May 9 2019, 10:59 AM
Marco (nacioss) added a subscriber: Marco (nacioss).May 9 2019, 2:45 PM
I definitely agree with you, the slots should be reversed.
Sebastian Parborg (zeddb) assigned this task to William Reynish (billreynish).May 10 2019, 12:50 PM
Brecht Van Lommel (brecht) removed William Reynish (billreynish) as the assignee of this task.May 10 2019, 12:52 PM
Brecht Van Lommel (brecht) lowered the priority of this task from 50 to Low.
Brecht Van Lommel (brecht) added subscribers: William Reynish (billreynish), Brecht Van Lommel (brecht).
@William Reynish (billreynish) is the UI designer, not a developer who can fix this.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.May 23 2019, 12:42 AM
I would not consider this a bug, certainly it can be improved but this kind of thing is outside the scope of the bug tracker.
Guillaume Audirac (gadic) added a comment.May 23 2019, 8:31 AM
I certainly did not consider this a bug but a suggestion for UI improvement. I did not think it was a big change.
Guillaume Audirac (gadic) added a comment.Jul 31 2019, 5:10 PM
@William Reynish (billreynish) Could this be re-opened to be added to the UI Paper Cuts? (https://developer.blender.org/T56950)
William Reynish (billreynish) added a comment.Jul 31 2019, 8:29 PM
Hmm yes I guess it could yes. I will add a new round of paper cuts now that the release is out.
